Old Feb 9, 2016, 10:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Check engine light reset?
Old May 1, 2005 | 12:22 PM
DubJunkE's Avatar
Sorry if this is old the search function is down.
But Im trying to get my check engine light reset after putting in a used motor without going to the dealer. Anyone know of an easy solution?
Thanks
Old May 1, 2005 | 03:42 PM
4Crawler's Avatar
Any hints as to the type and year engine/vehicle this might be in reference to?
With the earlier ECUs, just pulling the EFI fuse or disconneting the battery for a few minutes does the trick.
Old May 2, 2005 | 05:36 AM
DubJunkE's Avatar
Sorry Im a dumbass,
1990 4runner 3.0
Ive had the battery disconnected and tried touching the positve and negative terminals together while disconnected and that hasn't done it either.
So just seeing if there are any other ideas out there thanks
Old May 4, 2005 | 07:35 AM
cccp's Avatar
in my 90 toyota 4runner i just pulled the EFI fuse for about 10-15minuts and it reseteded and does not come on anymore. make sure it is the fuse.
Old May 4, 2005 | 07:44 AM
cccp's Avatar
if you want me to i can give how to read the check engine light step by step cause you have the same car is me, it worked for me.
Old May 4, 2005 | 02:43 PM
Tacoma Dude's Avatar
Do you know what the CEL is for?
Maybe it's not that you can't clear it but that you haven't yet solved the issue behind its activation?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
