89 auto trans shifter loose, real loose
Old Jun 3, 2005 | 12:06 PM
toyaholic's Avatar
I took the shifter assembly apart and see no obvious fix. my service manual has no mention of this. it looks as if there was some type of bushing or fitting that might be worn or missing. has anyone experienced this
Old Jun 3, 2005 | 05:33 PM
4Crawler's Avatar
I think there are some bushings on the linkage. Probably your best bet would be to stop by your local Toyota parts dept. (bring your VIN) and see if they can look the the shift linkage on their computer. Likely those parts would be Toyota-only items anyway.
Old Jun 5, 2005 | 05:01 PM
Bigblock's Avatar
I sawwed a piece of PVC (I think it was 1/2'') down one side and trimmed it to fit the inner shaft.It takes a little trial and error but it works perfect and will likely outlast whatever was in there to start with.Dont forget to grease it,or put a grease zerk in it.
this_guy
Jul 31, 2015 01:27 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
andrewtexas123
Jul 14, 2015 04:29 AM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
