Vacuum issue on 3VZE?
Old May 20, 2005 | 08:37 PM
fredtheturd's Avatar
Here's the problem: When my engine's hot & I'm stopped at a stop light with my foot on the brake & clutch, my motor doesn't maintain constant RPM's. Almost like it's loping. Also, sometimes when I idle the RPM's are around 1800 until I goose it & it drops back down to around 1000. I've asked a few buddies & they say I've got a vacuum leak, but I don't even know where to begin to look for vac line leaks for this problem. Thanks in advance for the help! Fred
Old May 21, 2005 | 06:52 AM
ChickenLover's Avatar
You can start by spraying carb cleaner on and around all of your vacuum lines with your engine running. When your engine starts to stumble/choke you've found the general area of the leak.
Old May 21, 2005 | 07:58 AM
4Crawler's Avatar
Most likely your idle speed is set too high. See this recent TLCA/Toyota Trails "Truck Tech" column for the full explanation:
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old May 25, 2005 | 08:32 PM
mtnfreak's Avatar
Check the air intake hose between the air filter an the throttle body. Any cracks will let in additional air an throw off the computer.
Old Jun 5, 2005 | 05:37 PM
Bigblock's Avatar
I've had this prob on all mine at one time or another.Most likely your throttle cable is binding slightly.Increase coil spring pressure on the throttle shaft.In other words ,make sure the throttle blades close completely.Next time try jabbing the go pedal and let it snap closed (running, out of gear)and it should return to curb idle.
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
