3vze wont run
Old Mar 30, 2005 | 04:44 PM
93cagedyota's Avatar
3vze wont run
I bought a new toyota last week for 1500 dollars that had a broken timing belt. I put a new belt on and set the timing and it ran good. I parked the truck for a week. Now the truck wont start. It pops, but thats about it. The truck has new bottom end and new heads. what can the problem be
Old Mar 30, 2005 | 04:54 PM
i also put a new distributor dandowney headers
Old Mar 30, 2005 | 05:38 PM
gwhayduke's Avatar
First thing I'd do is recheck the ignition timing. Then pull the front end off the engine and recheck your cam timing.
Ya really didn't want to hear this, did ya?
Old Mar 30, 2005 | 06:54 PM
thats what i was afraid of. Do you know what would cuse the cm timing to jump. I put a new belt on it and i was wondering if the belt tensioner would go bad for any reason. I was also wondering if it is a hydraulic tensioner. thank you
Old Mar 30, 2005 | 07:30 PM
Sludge's Avatar
Could be a bad bearing. Had that problem on my 91
Old Mar 31, 2005 | 03:33 AM
gwhayduke's Avatar
The bad bearings Sludge is talking about are in the idler pulleys and the belt tensioner. Also, I had difficulty setting the cam timing once when I tried to use an aftermarket timing belt. Sticking with a Toyota belt solved the problem.
Old Mar 31, 2005 | 09:24 AM
thanks alot guys, ill check that out
Doug4320
Mar 24, 2018 10:11 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
