30K Service
30K Service
Hi guys,
Called the Dealer and they wanted $207.00 for the 30K Service. This is what they do:
Oil change with Oil Filter
Change Air Filter
Change Coolant
Rotate Tires
Check all Fluids and top them off
Replace Sparkplug (if they are not platium)
I can do most of it except "Change the Coolant". How hard is to change the coolant? I do have a Gallon of Toyota Red Coolant at home. How much coolant does it need?
Change Air Filter
Change Coolant
Rotate Tires
You will need about 2.5 gallons -- You should get 2 gallons with the Toyota Red long life coolant when mix with distilled water and yes if you can do it yourself then do just that and save yourself $$$$ here is a link that may assist you with all the 30k maint requirements...
http://www.4x4wire.com/toyota/mainte...3.html#coolant
CPD4runner
9
Nov 5, 2017 06:01 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 20, 2015 06:15 PM
