3" lift
3" lift
if i can use a 3" block in the rear of a 2wd truck for a lift or lowering, can't i just use them to raise the whole damn truck (if i have a straight axle toyo, which i do?)
Guest
Posts: n/a
Re: 3" lift
Blocks can't be used in front, it's not safe. Do it right and keep the roads safe, we don't need any poorly lifted rigs falling apart on the road and killing some innocent family in turn giving us bad PR.
Re: Re: 3" lift
Originally posted by Churnd
i think it has to do with axle wrap.
crikey, did i say i was going to?...i was just curiuos as to whether or not i could.
makes sense..but do the aluminum block collapse as well? a long time ago, i had a truck that i initially used 3" blocks for lowering that were aluminum, and never had a problem. I have seen nylon blocks, and wouldnt touch them if they were given to me, much less pay for them.
i too have seen block lifts..thats why i was wondering. as for the shackles and body lifts, if i remember..they arent very cheap at all.
Lowering is a little different, they are what's known as "spring under" and the block is not supporting the weight of the vehicle, rather the u-bolts are. Still they shouldn't be used on the front no matter what. The material won't make much of a difference, the problem is the mostly concerning the length of the u-bolts and the leverage that's placed on them by the extended length.
hrm. interesting. as for springs, there are de-arched packs, as well as over-axles for lowered trucks...any variations on the standard pack for a 4x? besides shackeling and add-a-leaf? and just how many leafs CAN you add before its a liability?
Body lift ~$100 best place to get one is from Roger Brown, only guy who will custom build you a kit to your needs.
over-axles
over-axles
Adding leaves just stiffens the pack, it won't lift you much. Dropping leaves does the opposite, you won't lose quite as much lift as you would think but you will make the suspension very soft leading to poor road manners. Increasing the arch is what gives you the lift, and with the right combination of leaves of the right spring rate and arch you'll end up with a decent ride quality and plenty of flex all while staying safe.
i guess its a good thing i dont have a good memory, eh?
oh, and i guess what suspension work is all about, the amount of flex, correct? thats why they have those portable ramps that one drives a tire up as far as possible and they see how flexible the rig is..right? i guess im just looking for the most bang for my buck (which aint much) but nothing insane.
Real world performance is what matters.
well, like i said before, ive come straight from the pages of Mini Truckin', not Four Wheeler. The whole concept of working on my truck is now much more complex due to 4x, so its taking some getting to used to. Not to mention, I did a manufacturer-switch too. I just did some browsing, and it seems like shackles I shall go....for now
Co-Founder/Administrator
Also see this new forum at the bottom, and look for the lifting post in it.
https://www.yotatech.com/forums/foru...?s=&forumid=19
With a Roger Brown 1" body lift, and a rear shackle or add a leaf, he shows you how to fit 33's on an IFS rig without spending the big bucks for one of those expensive IFS lifts.
