Engine Swaps Swapping an engine in your Toy, here is where to learn how
sbc swap in 89 yota, lift???
Old Apr 19, 2009 | 04:58 PM
RDNEKkid's Avatar
im trying to swap a sbc in my 89' 4x4 pickup, and i was woundering if a lift was needed at all.
i havent decided weather im gonna use the adapter to my stock tranny or getting a tb350, i gues it depends on what cheaper and eaiser. any info is greatyl appreciated
thanks
Old Apr 20, 2009 | 11:00 AM
RevNL's Avatar
Yes.
2 or 3 inch body lift for clearance up top.
Suspension lift or a special oil pan for clearance on the bottom.
Or a solid axle swap.
Old Apr 20, 2009 | 11:41 AM
RDNEKkid's Avatar
so if i do a solid axle swap in the front, i wont need a lift, and if need be just drop shackles for the rear??
thanks for the info
Old Apr 21, 2009 | 02:07 PM
RevNL's Avatar
With the SAS, you can mount the engine low enough to not need a body lift but the SAS involves a bit of lift on its own. There are threads in the solid axle swap section covering low lift conversions.
Beware. I'm using a 700R4 and NP208 with no body lift. What I gained by not lifting the body, I lost from the transfer case hanging too low. Really low. It needs to be rotated up but that's a task for another day.
Old May 17, 2009 | 04:30 PM
sperkinsnwfl's Avatar
i have a 91 with a 350 /turbo350 advance adapter to the stock case mine just has a stock pan reshaped via 5pd. hammer not pretty but it works . i have a 3"bl and the chevy hei dist. its pretty tight with the sas and b/l you can drop the engine mounts low enough to get the distributor off the firewall or you could swap a ford motor in which is what i wish mine had ..... either way a v8 in a yota is a lot of fun nothin like smoking some 33's down the road
Old Oct 10, 2009 | 10:13 PM
liftit's Avatar
im doing a 350 swap right now and if you go to advanced adapters they actually have a booklet for chevy v8/v6 swaps, they say it is best to have a sas with suspention lift and they recommend a body lift of at least 2" for better clearince. but another thing to think about with a 350 swap its a little harder for the fact that the distributer is in the back of the motor unlike a ford with the distributer in the front. for me i already had a built 350 in my garage but even if i didnt i could put a ford motor in my truck, im too much of a chevy guy
Old Mar 5, 2012 | 06:26 PM
283yotacrawler's Avatar
What kind of clutch set up are guys running with a stock sr5 5spd. Is there something Gm offers with flywheel and pressure plate set up with factory sbc flywheel that will fit the input shaft of the tranny? I dont want to have to flywheel drill to mate the the toyoya clutch? or is that what i have to do. Im building a chevy 283 and trying to run it with stock 5spd for now. 2 in bl. with 3 in suspension lift. I would like to see what people have to say..
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
akaphilly
Jul 9, 2015 02:18 PM
