Engine Swaps Swapping an engine in your Toy, here is where to learn how
Remove dipstick?
Old Sep 20, 2011 | 01:48 PM
RajabuYota's Avatar
Remove dipstick?
I'm swapping my 22re for a rebuilt one and can't figure out how to remove the dipstick so I can install it into the new one. Any help?
Old Sep 20, 2011 | 01:53 PM
xxxtreme22r's Avatar
Pull straight up just like you would if your checking the oil.
Or do you mean the dipstick tube?
Got to unbolt it from the block and it should come right out.
Old Sep 20, 2011 | 01:55 PM
snobdds's Avatar
I just gave mine a good yank - for lack of a better term.
If it's really tight, just take a sharp chizel and CAREFULLY go around the bottom where it meets the block and pry it up. It's just pressed fited in there.
Old Sep 20, 2011 | 01:57 PM
dang it snobdds now I got to go look at mine, I coulda swore mine was bolted down.
Old Sep 20, 2011 | 02:00 PM
snobdds's Avatar
The top part has a little holder that bolts to the block/head, but where it goes into the block is just a press fit.
Old Sep 20, 2011 | 02:31 PM
RajabuYota's Avatar
Haha my mistake, I meant dipstick tube... so it pulls straight out with a little elbow grease? Sounds good, I was worried that it was welded in or something. Thanks!
Old Nov 2, 2011 | 01:28 AM
Rebel Lady's Avatar
yes I tried pull the tube of oil dipstick and cant pull it out.
Old Nov 2, 2011 | 02:33 AM
suncomb1's Avatar
Drop the oil pan, take a punch that is close to the dipstick hole ID, spray WD-40 and gently tap it out. Doing it this way you will not damage the dipstick tube. I just replaced mine with a Lokar unit.
Old Nov 2, 2011 | 03:01 AM
Rebel Lady's Avatar
thanks,Suncomb1
I ll do..
Old Jan 10, 2012 | 11:31 AM
Newby's Avatar
Great that you got it out.
choppe777
May 16, 2016 08:00 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
gp66
Sep 7, 2015 08:29 AM
viesail
Sep 5, 2015 04:23 AM
Aaron Logan
Sep 3, 2015 08:08 AM
