Engine Swaps Swapping an engine in your Toy, here is where to learn how
Questions about doing a possible 3rz swap into a 2wd 1992 Toyota P/U (22re).
Old Mar 18, 2013 | 07:04 PM
pskaibab's Avatar
Trying to get some info on the T100 oil pan mod for putting a 3rz into a 2wd
I have talked to the guy at ToyOnlySwaps and Chilkat (I know that Chilkat also modifies the T100 oil panand understand that I need to modify the crossmember of the IFS or mod the a T100 oil pan. I was wondering if any of the people who current these forums could show or tell how they modified their T100 (3/2rz engines) oil pan? (The 4wd 3rz swap posts do not give me much of any information as far as keeping the 2wd IFS)
I have a 1992 Toyota Pickup (standard model w/ a shortbed) with a W55 Transmission and a 22RE engine. I do not want to convert to 4wd or do an SAS.
I want to put in a 97 2wd T100 3RZ-FE engine (if still available, if not I'll get the ECU). I also understand what an undertaking this is. This would be my first swap if it ever gets off the ground. There is a chance I might try a 2rz but I really want to go for a 3rz.
Also what wiring harnesses would fit the T100 ECU (I plan to go stock T100 wiring, but the harness might be pricey at the same salvage yard)?
Last edited by pskaibab; May 1, 2013 at 02:46 PM. Reason: Trying to perfect my question a little more....
Hatch man
May 17, 2026 11:40 AM
GreenLion
Jun 7, 2021 10:49 AM
irish_tyrant
Jul 6, 2015 11:22 AM
hhsanfor
Jun 30, 2015 06:08 PM
DanStew
Jun 29, 2015 10:46 AM
