Engine Swaps Swapping an engine in your Toy, here is where to learn how
all swaps and costs
Old Sep 26, 2009 | 11:45 AM
hjkmotor's Avatar
all swaps and costs
so there are i don't know how many threads for engine swaps on this forum. tons of successes, tons of lost causes, and tons of who knows?.
anyway in my search for a possible swap lets post up our swaps and costs of said swaps. that way others can choose what swap they want to do. maybe we can create a sticky
include engine, tranny, cost, custom parts required, etc. keep it simple please we can all go find a write-up if we're interested in a certain swap we find here.
Old Sep 26, 2009 | 01:15 PM
hjkmotor's Avatar
bump..... come on guys. lets start with the basics 3vze to 22re, 3.0 to 3.4. what we lookin at in costs.
Old Sep 26, 2009 | 09:27 PM
Adam F's Avatar
Every swap will be different, but here's how mine broke down
3.0 to Chevy 350
Engine came from a 1976 Blazer. Bought it off my brother for $250. Took the engine, parted the rest and made my money back, so the engine cost me nothing.
Transmission is the stock R150 5 speed from my 3.0, and stock t-case. So no cost there.
I scrounged together scrap steel and various nuts and bolts from home and work, so I diddnt have to buy much raw material.
Pulled the 3.0 and parted it out. Made about $200 on it.
Plugs, wires, coil, cap, rotor, seal kit, timing chain, oil filter, fuel filter, fuel lines, degreaser, paint, and other misc maintenence items to freshen up 350 $400
Advance Adapters bellhousing adapter $450
Centerforce flywheel, clutch disk, and TO bearing $360
153 tooth flywheel $50
Ebay mini starter $90
Ebay block hugger headers $80
Dual glasspacks and pipes $100
Motor mounts $75
Taurus fan $50
Temp controller and solenoid for fan $75
83 Camaro radiator $100
Driveshaft work $150
Now I KNOW im missing something, but so far thats $1930
I had to buy an engine stand and engine hoist, so add another $50 for the stand and $130 for the hoist
I had to have gone through $50 or $60 in grinding wheels and cut off blades
Running total, $2220
And thats being a tight ass. I could have bought a bunch of stuff I made, and used more expensive custom parts instead of the frankenstein parts I used.
Old Sep 26, 2009 | 11:43 PM
RMA's Avatar
RMA
so heres how I see mine. If I think of anything else Ill add to it.
v6 3.0 A340H auto to Lexus v8 1uz A341E auto
1992 Ls 400 running current reg............. $1100
Inchworm prerunner adapter...................$750
modify driveshafts................................$275
Summit alum radiator sum-380325...........$159.95
customize in and outs on radiator............$100
2003 Tundra manifolds (ebay)................$50
custom dash........................................$150
steel (motor mounts )............................$24
summit exhaust wrap.............................$37.75
summit wrap ties..................................$27.90
summit trans cooler der-13224................$29.95
summit adj temp probe der-16749...........$39.95
summit 2x10" 2350cfm fans prm-19120......$145.90
new belt (no A/C)..................................$31.99
fittings ,hose clamps,shrink tubing,solder....$30
customize(bend) 3/8 steel for crossmember.$40
exhaust work.........................................$100
21 spline frward shift gear case (norcrawler)$100
.................................................. ........$3192.39
sold
ls 400 parts so far................................$1600
3.0 engine from truck (no acc).............$600
A340 tranny from truck........................$250
acc from truck starter,alt, compressor......$100
.................................................. .......$2550
Had spent some money on rebuilding another 3.0 then changed my mind and did the 1uz swap, so just moved some money around .
sold
rebuilt 3.0 block and full gasket set........$750
used 3.0 downey headers....................$200
rebuilt 3.0 heads.................................$250
.................................................. ....$1200
I think thats it.
Old Sep 27, 2009 | 08:11 AM
hjkmotor's Avatar
awesome, these r the kinda posts im looking for. simple breakdowns.
Old Oct 23, 2009 | 09:45 AM
gabe74gt's Avatar
this post has helped me to get those swaps. thanks for that. and i am looking for more like that! keep it up guys
Old Oct 24, 2009 | 06:04 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
1986 4-Runner 22RE to 4.3 CPI/700R4
Complete Donor 1992 Chevy 2wd Blazer $500
Adapter (AA from Inchworm) $550
Tranny Shop to install tailshaft $150
B&M Shifter $100
Fuel lines and -AN fittings $50
Fabbed Motor Mounts $0
Stock Chevy Radiator $0
T-Case mounts at same location, no driveshaft mods.
I can run either a clutch fan, or electrics $0
22RE fuel pump works but I am running an inline $90
The power is priceless.
Old Oct 24, 2009 | 06:35 AM
RobD's Avatar
Complete 3.4 cost me $2000. Custom crossover to route the exhaust from the passenger side to the driver side, $200. Rest of the exhaust, including two new O2 sensors, about $800, though I think I got a little hooped on that price. Misc bits and pieces, about $500. So, roughly $3500. Sold the old 3.0 for $300, probably could have gotten more, I just wanted it out of my brother's garage.
Call it $3200.
Old Oct 26, 2009 | 03:43 AM
dunnarunner's Avatar
I envy you people on the costs of things you have in America, in Australia things are very different in prices. I bought my 85 4 Runner for $4500.00
Holden 308 motor for $1500.00
355 stroker kit $1200.00
TH700 transmission $1100.00
Adaptor kit for transfer case $850.00
Interfaces for electronic fuel injection$480.00
Pumps and relays and mounting brackets $650.00
Shift mount and display $350.00
I have to point out that my costs are in Australian dollars and probably mean nothing to you guys but I thought i would share it with you anyway.
Clive.
Old Oct 26, 2009 | 03:59 AM
hjkmotor's Avatar
dont feel bad dunnarunner. we envy the parts that u can get and we cant lol
Old Oct 30, 2009 | 06:49 PM
94toyota's Avatar
the 1uz is one of the best swaps ive seen it is a bout the same cost as a chevy 350 and when we dynoed a stock lexus sc400 and a72 camaro with a 350 with 500 4bl and hooker headers at my school the lexus had more rwhp and rwtg it also revved up to about 7800
Old Oct 30, 2009 | 10:10 PM
kiyobrown's Avatar
Awesome. Its like finally getting an answer. I find so many threads that suck me in for 3 pages and then BAM, no ending....
coleypull15
Nov 3, 2015 07:41 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
GeoRoss
Jul 24, 2015 03:03 PM
Coreyr384
Jul 10, 2015 11:13 AM
skoti89
Jul 6, 2015 07:45 PM
