Engine Swaps Swapping an engine in your Toy, here is where to learn how
3vze Manual to Auto
Old Sep 26, 2020 | 03:44 PM
Snake428's Avatar
Exclamation 3vze Manual to Auto
Gidday yota members,
I'm in abit of a pickle. Seems I have either blown my HG near the exhaust chambers or I have a crack in my head so it's time for a new motor, I have another 3vze motor lined up but its coming from a factory manual hilux surf/4runner. Mine is factory auto. Apart from the obvious is there anything I need to change when I swap motors over? Like is the flywheel bolt pattern the same? Is the bell housing bolt positions the same? I havent taken my motor out yet and probably wont before I pickup the bee motor. So thought I would come here and ask for advice before I move forward. I'm sorry if this has already been answered somewhere in the forums, I searched but had no luck.
Cheers guys and gals 🤙
Old Sep 26, 2020 | 06:06 PM
moto809's Avatar
5 Year Member
The 3vz auto and manual trans both use the same bolt pattern for both the bell housing and crankshaft. Your new engine should slide right in without a fuss.
Old Oct 16, 2020 | 09:15 PM
Snake428's Avatar
do I need to remove spigot bearing?
Old Oct 17, 2020 | 05:46 AM
moto809's Avatar
5 Year Member
No it should be fine to leave it in the crank if you don't feel like removing it.
Old Oct 17, 2020 | 12:56 PM
Snake428's Avatar
Thanks for your reply. however you do have to remove it. I didnt bother yesterday and I could not get the trand to line up, 1 side will get close to bolted and other side wouldnt, I removed spigot bearing and on 2nd attempted the trans slipped right in 😉
Old Oct 17, 2020 | 01:19 PM
moto809's Avatar
5 Year Member
Interesting, I don't remember anything using that hole on the auto application. Anyways, glad you got it
Old Oct 17, 2020 | 01:26 PM
Snake428's Avatar
I didnt think so either. But pulling motor out and looking at the end of the torque converter it's clear as day what needed to go where. Good to know for future reference and hopefully my thread will help someone else. I attached photos showing the end of my trans 😝
Old Oct 18, 2020 | 07:38 AM
Co_94_PU's Avatar
Yep centering lug on TC, you won't be happy if you bent or broken this.
flag4runner
Engine Swaps
Aug 11, 2017 08:29 PM
Squamch
Engine Swaps
Jan 16, 2014 01:51 PM
gb42
Oct 30, 2011 04:19 PM
zbadboy
Aug 20, 2009 10:28 PM
radrex
Apr 3, 2004 05:07 PM
