Engine Swaps Swapping an engine in your Toy, here is where to learn how
3VZ-E Pull & Drop In
Old Jun 25, 2012 | 09:20 PM
west_89_'s Avatar
hey iv scored a great 94, 4x4, single cab, short box, with a perfect frame and body. but with a 3VZ-E with a busted timing belt ( not worth fixing). and i have a donor truck with a great condition 3VZ-E. Im wondering if any one has a link to a good thread on pulling and dropping in of the 3VZ-E?
Old Jul 2, 2012 | 09:48 PM
nathanmyers's Avatar
I don't have a link but it is a fairly simple swap... use google and the search box. there is stuff on here on pulling and dropping in but seriously just go tackle the thing. you can figure it out. just get a manual and remember to replace the transmission front seal and just pull the motor not the motor and trans. I can pull one in about 5 hours and have one in in another 10 ish but I have done it several times.
Old Jul 3, 2012 | 06:02 AM
rattlewagon's Avatar
Depending on what year motor your dropping in some of the plugs might be different, but its pretty straight forward.
Old Jul 7, 2012 | 06:08 AM
west_89_'s Avatar
thanks. ya i just went at here took lots of pics and labled everything. almost as simple as a 22re just a little less space to work with.
Old Jul 7, 2012 | 06:10 AM
west_89_'s Avatar
are you talking about the rear oil seal in front of the clutch and flywheele and pressure plate? or is this a diffrent seal?
if so plz more details.
Old Jul 7, 2012 | 06:14 AM
west_89_'s Avatar
yea some is defferent whats is it better to just swap everything over?
Old Sep 3, 2012 | 08:26 PM
bmcghie's Avatar
west_89_, he was referring to the seal around the input shaft of the transmission. You need to take off a mounting bracket inside at the rear of the bellhousing I believe. As if you were going to change the tranny input bearing... but just do the seal. They tend to leak often than many other seals, so most people recommend replacing it if the bellhousing is ever open.
Oh yeah, do the engine's rear main seal as well though.
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
shisha1999
Jul 13, 2015 11:09 PM
Jnkml
Jul 6, 2015 01:20 PM
