Engine Swaps Swapping an engine in your Toy, here is where to learn how
2000 long block into 1998
Old 02-04-2010, 12:16 PM
jrock's Avatar
SO ive got a lead on a $500 25k 3.4 from a 2000 4runner. its just the long block. Whats the chances of this working in my truck(98 4runner 3.4 4x4/5spd), w/my wire harness/ecu?
I guess i could always buy sep wire harness/ecu for it...
Im trying to determine if its EGR or not as mine is not, nor r my new DT headers..Are 2ks dual cats?
engines from 4x4 rigs have different oil pans right?
what else?
Old 02-04-2010, 12:25 PM
Staff
DeathCougar's Avatar
Here is what you have worry about with the donor long block.
*crickets chirp*
Thats right, nothing. You will have to swap your wiring, and ecu, and probably some sensors, but other than that the engines are 100% the exact same.
HOWEVER!! If this is a Japanese crate engine, you are on your own.
If not, then just switch some things over and drive. 2WD and 4WD 4Runners use the exact same oil pan, since 2wd 4runners are technically just 4wd delete.
Old 02-04-2010, 01:12 PM
jrock's Avatar
sounds good! its not jap crate, its from guy in AZ whom has had it sitting in his shop for years....
now if it does have EGR, what should I do bot that...Is there a way to "plug" up the EGR port...otherwise id have to get EGR headers right?
Old 02-04-2010, 03:04 PM
Staff
They will be the same motor. I don't think they use an EGR.
Old 02-04-2010, 04:59 PM
jrock's Avatar
Well i believe cars that were Ca. spec have EGR. Thats why when you order Doug Thorley headers for a 98 you have to first select EGR/no EGR. ie., URDs site.
thx for the responses!
Old 02-06-2010, 11:04 PM
tacklebox421's Avatar
where can you find those doug thorley headers for a 98 4runner ive looked and cant find them
Old 02-08-2010, 05:09 PM
jrock's Avatar
http://www.urdusa.com/product_info.p...9cn27fu40cotm3
http://www.urdusa.com/product_info.p..._id=1260518585
Theres usually a group buy going on...Search customtacos..i think the last GB paid $550 ...URD will match $.
As u see EGR headers are more $.
Anyway to make an EGR engine non-EGR?
the1998sr5
15
07-14-2020 08:35 PM
yourrealdad
07-21-2015 11:13 AM
bigjstang
07-12-2015 12:31 PM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 2000 long block into 1998
