4Wheeling 101 Discussion pertaining to the proper use of your off road gear and recovery techniques
? on wheeling on sand(beach)??
Old Oct 30, 2007 | 07:29 PM
treknwil's Avatar
OK! I'm going to Pismo Beach CA this weekend for the Cruiser Surf n Turf taking the FJC., but I've never wheeled in the sand before! I know to air down but how low? And what gear ? 4low or 4hi? Any tips would be great!!
Old Oct 30, 2007 | 07:58 PM
slosurfer's Avatar
I would start out at around 15psi and see how it feels and then lower from there. 10 is more realistic but 15 will give you a good place to start. You'll be fine in 4hi starting out. In my 4runner I go back and forth between 2hi, 4hi, and 4lo the whole time out there, but I can do all that on the fly. I know in my wifes tacoma, I can only go between 2hi and 4hi on the fly.
A good trick for speed, start out in 4hi and once you are moving pretty good and on top of the sand, switch it to 2hi and you can really get some speed.
See you out there!
Old Oct 30, 2007 | 08:53 PM
toy_tek's Avatar
I just wheeled all over Glamis last weekend and it surprised the heck out of me how well the truck did. Had 10psi in the tires and used 4 lo & 4 hi.
Old Oct 30, 2007 | 09:10 PM
tc's Avatar
tc
Don't be scared of single digit pressures if you need to!
Big key is when you lose momentum, EASY on the throttle. The absolute worst thing you can do is start spinning the tires - you will dig in EASY and FAST.
Old Oct 31, 2007 | 08:11 AM
4Crawler's Avatar
I put together some sand wheeling tips on my web page:
http://www.4crawler.com/4x4/PismoBea...#DrivingInSand
Old Oct 31, 2007 | 08:34 AM
dropzone's Avatar
Fossilized
1. Have a good compressor so that you can air back up with.
2. Make sure you have a real tow strap and tow points to hook the strap up to.
3. Take a shovel and cut some strips of plywood 4'x18" just in case
Jcrawl94
10
Oct 24, 2015 04:34 PM
Dakotaneu
Aug 15, 2015 07:24 AM
jjrbus
Aug 10, 2015 01:09 PM
Up&Down
Aug 5, 2015 06:20 AM
skoti89
Jul 6, 2015 07:45 PM
