Wheel Backspacing question..
Old Jul 26, 2008 | 09:35 AM
pepsibluefloat's Avatar
Im doing a 3" SAS on my 4runner and its time for me to buy wheels and tires. Im going w/ 35's on 15x10 wheels. With the SAS ive got the 1.5" wheel spacers to make the front axle the same width as the rear.
what do ya'll think good backspacing would be?
Old Jul 26, 2008 | 09:50 AM
4Crawler's Avatar
Stock is 4.75", with the spacers up front you'll be fine w/ stock backspacing and with the added wheel width, you'll already be 6" wider than stock (3" per side). So it all depends on how wide you want to end up:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Old Jul 26, 2008 | 09:56 AM
awesome, so 4" backspacing should have no problem with rubbing then.
thanks for the quick reply
Old Jul 26, 2008 | 10:52 AM
4Crawler's Avatar
If your current tires and stock wheels work fine w/o rubbing, then anything with less backspacing should be fine. You can check clearances around your current tires to see if there is room for the larger tire. Measure out in radius 1/2 the difference in tire height and in/out from the tread edge 1/2 the difference in tire width to see.
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
