knuckle ball gussets ?
Old Jul 27, 2008 | 05:13 AM
HAVOC's Avatar
Question knuckle ball gussets ?
I'm waiting on some parts to start rebuilding my 1984 solid axle. I'm not sure if I need the knuckle ball gusset kit.
The truck will see mud and light trails. It will also be used as a DD. Would it just be a good idea seeing on how cheap the kit is?
Thanks.
Old Jul 27, 2008 | 05:33 AM
waskillywabbit's Avatar
If the axle is going to bend...it is going to bend at the knuckle ball.
Old Jul 27, 2008 | 06:11 AM
Yoda's Avatar
Big fat tires and spacers etc put a lot more stress on that part.
If you have it apart anyway, why not?
Old Jul 27, 2008 | 06:21 AM
HAVOC's Avatar
That's what I was thinking. Now I need to cut the factory lower shock mounts off. I'm ordering these from wabfab because I don't like the lower shock mounting on marlin's part.
<edit> I just ordered them through Paypal. Can I use the dual transfer case crossmember with a single case? Do they make a single case crossmember like the one in the picture?
Thanks again.
Old Jul 27, 2008 | 06:23 AM
dirtoyboy's Avatar
YES you need them......also cap your steering stops or weld a nut inside
especially if you ever want to jump your truck....
I prefer the stock "double shear" design like trail gear over most of the other kits.
I would also recommend making your own kit. Here's one I made for a SAS I was working on. We used a cheapie shock mount and modified it for the top.
VERY IMPORTANT: make sure you install (or partially install) the knuckle and turn lock to lock to make sure the gussets clear. I know that Marlins kit requires quite a bit of trimming and its a pain in the ass to fix after you've welded it in all the way..
Use a small piece of round tube. This also allows the gusset to slide over a rock if it makes contact.
Old Jul 27, 2008 | 06:41 AM
HAVOC's Avatar
I will be capping the steering stops (they look too weak even for normal driving). I like the tube used as a gusset, someone should sell those (hint, hint). I'm having a friend at work do some of the welding, I could do everything else, except weld. I should look into taking a welding class.
Old Jul 29, 2008 | 06:23 AM
4RunnerKid's Avatar
yes
Old Jul 29, 2008 | 12:00 PM
Blizzard's Avatar
I've the Trail-Gear ones too:
Also put the Rock Rings
And backing plate eliminators:
David
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
toyotasaurus
Sep 24, 2015 03:30 PM
