what do i do for master on gen 3 4 runner
Old Apr 16, 2007 | 02:17 PM
allbentup's Avatar
So i am all most done with my sas on a gen 3 4 runner but i am having a problem with the brakes. I am running a d60 in the rear with disc brakes and i still have the stock resevoir. I looked at the one from rockstomper and i was told that wont work....so who else is runing 3/4 ton axels w disc on all 4 corners??????? and what are you running?????
Old Apr 16, 2007 | 04:43 PM
smashmetal's Avatar
Im in the middle of a major swap myself that includes disks all the way around. I found this and was just going to try what they did
https://www.yotatech.com/forums/f116/rear-disc-swap-107749/
And if this don't work than Ill be finding a proportioning valve out of an older GM vehicial with disk brakes. I did this before on my blazer when I did the swap and it worked awsome.
Old Apr 16, 2007 | 09:09 PM
allbentup's Avatar
i bought a proportioning valve that is a must when running disc in the back, there just isnt enough weight back there. but on the resivor that wont work with 3/4 ton or larger discs it just doesnt have enough volume for the calipers. what year are you doing your swap on? Rock stomper sells a kit for all 4 bolt master cyc. my 4 runner is a 97 or a gen 3 and no one has anything for that....i remember seeing a write up on pirate about a guy who used a chevy 1 ton with a vacuem boost style so that is what i am going to try.
Old Apr 17, 2007 | 12:20 PM
smashmetal's Avatar
Well mine is a 93. I just figured that Just as long as the proporting valve was set for rear disks it would be allright. I thought that once the system is full of fluid and blead out it would be ok.
But im not that far yet, makes me a little concerned because I've got a dana 60 up front with larger calipers on it than the rear will have.
Keep us up to date!
Old Apr 18, 2007 | 10:01 PM
allbentup's Avatar
bought a chevy 1 ton master cyc today and it looks doable if it doesnt rain ill be working on it this weekend...ill take some pics.
Old Apr 22, 2007 | 02:09 PM
smashmetal's Avatar
I just meet a guy who has done the completed a 1 tone swap on his 4runner he said this is what he used and it works great!
http://www.rockstomper.com/catalog/b...mtoymaster.htm
Old Apr 26, 2007 | 09:20 PM
allbentup's Avatar
ya that wont work for me i have a two bolt not a 4 bolt
Old Apr 26, 2007 | 10:44 PM
Elvota's Avatar
Have you found this link yet:
Click me:
Has lot's of master info towards the bottom... might help you in the right direction
Old May 7, 2007 | 09:56 AM
smashmetal's Avatar
I also found this. scroll down untill you see the pic's of the master cylinder.
http://www.pirate4x4.com/forum/showt...=531939&page=4
It's a much nicer peice the rock stomper, I think they said they got it from Skys.
Old May 7, 2007 | 04:48 PM
smashmetal's Avatar
After making the above post I had to give Sky's Manufacturing a call to see if they made the adapter for a GM master cylinder.
http://www.sky-manufacturing.com/
I ended up ordering one myself. The kit consists of the adapter plate to put a GM master cylinder on a toyota brake booster and all of the attaching hardwear. Price was $35 and about $5-10 for shipping ill throw up a total when it arrives. It was a new guy that took my order and he wasent to fimiliar with the shipping part of the transaction.
Old May 7, 2007 | 05:04 PM
smashmetal's Avatar
Wow I really need to pay attention to what is written! I totally missed the year of the rig your working on. Any way, I don't see why you couldent make your own spacer like the Sky's or Rock Stomper but for your application.
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
