wat year toyota front axel is the best?
Old Nov 13, 2007 | 11:23 PM
kauaiboy89's Avatar
anybody?
Old Nov 14, 2007 | 05:06 AM
waskillywabbit's Avatar
You want one with the OEM truss on it like an 84 or 85 4Runner/Pickup.
Old Nov 14, 2007 | 02:20 PM
chimmike's Avatar
did you look at the titles of threads before you posted this new one?
this thread https://www.yotatech.com/forums/f152...ations-129276/ was only a few down from yours when I looked...
Old Nov 20, 2007 | 08:30 PM
Stomis's Avatar
A 2007 tacoma SFA is damn strong...
Old Nov 23, 2007 | 05:57 PM
dirtoyboy's Avatar
u want an earlier style axle, with no truss on the bottom! extra ½ inch ground clearance under the axle tube baby!
Old Nov 24, 2007 | 09:30 AM
fillsrunner4's Avatar
this is actualy a good idea as you can easily add a truss to the top bigger and stonger
Old Nov 25, 2007 | 04:40 PM
dirtoyboy's Avatar
yup.....
do you know of anyone that has bent their axle tube DOWN? i dont
most of them bend at the knuckle ball
Old Nov 26, 2007 | 12:06 PM
bigarms23's Avatar
I have an 83 axles but look for an 83-to85 or spend the cheddar and buy a diamond housing
Old Nov 26, 2007 | 12:10 PM
jjrgr21's Avatar
BIGARMS you are one lucky SOB, living in truckee, have you'all got any snow yet.
Old Nov 26, 2007 | 12:50 PM
yup.....
No i dont know of anyone whos bent one down could it happen? the early axles still have a truss dont they? its just not all the way to the outside of the perch so i guess ground clearence in a small spot would be robbed with a newer one and also like stated above its gonna cost more for the newer. as for bending knuckles just buy the creeper gussets from trail-gear or make your own Marlin also sells some but i like the trail-gear design sorry marlin. they are a great upgrade aspecialy for like $35 and if you want to buy a upper gusset they are also pretty cheap. i just made my own
Old Nov 26, 2007 | 03:20 PM
toy283's Avatar
I prefer the '81-'83 models with the partial truss. The full truss on the later years makes u-bolt flips more complicated because of the squarish cross-section of the axle. The earlier ones still have a truss out to the spring but the axle tube is round. Extra trussing is easily done on your own.
Old Nov 26, 2007 | 04:27 PM
I found the way you can bend an axle down and it makes plenty of sense. if you bottom out your suspension it puts a huge load on the axle downwards thus making it vital you have good bumpstops even with them though you can bend an axle down. as for my question about the truss, on all the earlier than 81 dont have a truss.
Toy283 is right about the flip kits but even with the truss its not to hard to make it work
Old Nov 26, 2007 | 04:39 PM
d0ubledown's Avatar
front axle from the 60 if you can make it work.
Old Nov 26, 2007 | 05:10 PM
Hayes's Avatar
Save for the diamonds if you don't already have a solid axle. I will be getting the diamonds as soon as I get some other things taken care of...gears, lockers, engine rebuild...then DIAMONDS all the way!
Old Nov 26, 2007 | 07:53 PM
hodgepodge79's Avatar
anyone have pics of what these different styles of factory trusses look like. What other key features distinguish an '81-'83 from an '84-'85 ?
Old Nov 28, 2007 | 06:01 PM
bump...
Scotttekoch
23
Nov 1, 2021 12:41 PM
6th Gear
19
Dec 10, 2019 07:31 AM
vasinvictor
Jan 20, 2016 12:39 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
