Uneven leaf springs
Old Oct 31, 2007 | 03:09 PM
blazerboy72's Avatar
Uneven leaf springs
Is it common for leaf springs to be different heights? I have a set of allpro springs on my 4Runner and the passenger side is about 1.5"-2.0" lower than the drivers side. I would contact allpro but they have been no help in the past when I have tried.
Old Oct 31, 2007 | 03:18 PM
Blizzard's Avatar
Have you tried to side-swap them? Seems to work to a lot of people...
David
Old Oct 31, 2007 | 03:46 PM
no I havent. I have a dana 44 so the perches are the same height on both sides, but I will try swapping them one day and see what happens.
Old Nov 1, 2007 | 02:44 AM
Blizzard's Avatar
I think it's due to more weight in the PS of the truck...
David
Old Nov 1, 2007 | 08:29 AM
UKMyers's Avatar
I just had this same issue with my TG 5" springs. My ruck was leaning to the right. I swapped the front ones first and that didn't work so I swapped the rear ones and that fixed it.
Old Nov 1, 2007 | 09:38 AM
Was yours leaning in the front or rear or both? My rear seems to sit pretty level it is just the front that is leaning. I am goin to go try mine now.
Old Nov 1, 2007 | 02:40 PM
I switched the springs but it made no difference. Im not sure what to check next.
Old Nov 3, 2007 | 12:02 PM
spaceycayce's Avatar
its probably the weight factor, I have the TG springs and after about 6 months now they've settled a bit. I noticed a lean on the right hand side as well(passenger). I think others are right it has to do with the heavy stuff(gas tank, t-case, etc.) being located on that side.
Old Nov 3, 2007 | 12:37 PM
Probably so. I will try it for a while and see waht happens. Im not sure the 4" springs are going to hold up the v8 very well anyway.
Old Nov 3, 2007 | 12:41 PM
waskillywabbit's Avatar
I'd recheck your mounting points as well as you might have one side off just a tad and that would affect things that much.
Old Nov 3, 2007 | 02:36 PM
I have measured them several times and everything seems to be the same side to side. Hopefully they will level out when they are broken in or I may be placing an order with you.
Old Nov 6, 2007 | 02:08 PM
AZ4ME's Avatar
I have the All Pro springs on my 4runner and I have the "Gangsta Lean" to the passenger side also. About 1.5" in the front and about 1" in the rear. Springs are relatively new ~4 months. Only been out about 5 times. It's fairly common.
Old Nov 6, 2007 | 02:22 PM
I will see what happens. I havent flexed them or even driven with them yet so maybe it will level out.
Old Nov 6, 2007 | 06:08 PM
chimmike's Avatar
I've got the same problem, and my springs are definitely worn in by now, my right side sits lower than the left.
I've got one thing I'm going to try while swapping but we'll see.
Old Nov 7, 2007 | 02:51 PM
Atleast I wont be the only one riding around with a leaning truck.
Old Dec 17, 2007 | 08:52 PM
seafarinman's Avatar
Hey guys, I am running AP 5" springs and my **left** side is the one that is sagging on the rear corner. I would understand if it was the right side since the gas tank is back there and all. I guess that I will try swapping the rear springs tomorrow.
Old Dec 18, 2007 | 02:29 PM
I still havent figured mine out. I have driven it some now and it seems to lean worse now than before.
Old Dec 21, 2007 | 06:45 PM
Well I got my springs swapped right to left and I re-installed the overloads and it appears that there is still some sag on the left side so maybe my frame is tweaked.
Old Dec 22, 2007 | 10:42 AM
neoworm0's Avatar
Add my name to the list. I've had a pass. side lean ever since my leaves broke in. I tried swapping the springs left to right but it didn't help. I've kind of learned to ignore it.
Old Dec 23, 2007 | 02:36 PM
4Crawler's Avatar
Did you use a spring perch spacer on the driver's side front perch?
