turbo 22 RE
turbo 22 RE
Hi, I have a 1982 toyota pickup, i dropped in rare turbo 22re, swapped the turbo for a bigger watercooled eagle talon turbo intercooled through a toyota celica air/water intercooler system and i wired in the SDS stand alone computer system to make it all work. The thing really barks now, im guessing around 250 hp with 17lbs of boost.
I just ordered my 38"x11 interco's, my diffs/axles arent going to hold up are they? What beefy axles should i through under my toy to make it all work (aussi locker installed front and rear)? What should i do about the transmission and transfer case? I want this thing to dominate the high rider competition in Drumheller, Alberta this summer. http://www.highriders.ca/4x4_events.htm
Im cheap everything available at the local junkyard pls!
Help me kick some arse the toyota way!
Chromoly Longsfields. Only way, if you want to keep the toyota housing, unless you want to use the birfield eliminators.
http://www.longfieldsuperaxles.com/
TheBFA
Feb 15, 2020 06:55 AM
CPD4runner
9
Nov 5, 2017 06:01 AM
voiddweller
53
Feb 1, 2016 05:46 AM
