Solid Front Axle Recommendations
Old Nov 8, 2007 | 07:22 AM
Trail_Banger's Avatar
I've been researching solid front axle swaps and thought I'd ask this forum what people's opinions are on the best axles and parts to use. Who sells the best complete kit? Does anyoen thing it's better to get separate parts and build up that way?
I have a 1989 regular cab truck with the 3.0 and 5 speed.
Thanks!
Old Nov 8, 2007 | 07:26 AM
dropzone's Avatar
Fossilized
84-85 SA if you can find one and want to use toyota...
Old Nov 8, 2007 | 08:45 AM
AxleIke's Avatar
Get a kit. Cost is the same either way, and you have less hassle.
Check out Wabbit here on the forum. He sells good kits.
Old Nov 8, 2007 | 08:55 AM
ForeignMuscle's Avatar
wagoneer dana 44 or just a yota axle will do it, gusset the axle before you put it in
Old Nov 8, 2007 | 09:18 AM
jjrgr21's Avatar
X2
for the DANA 44
Old Nov 8, 2007 | 11:44 AM
fillsrunner4's Avatar
could go with a high pinion Land cruiser front maybe a air locker or elocker that would be sick, wide and strong plus then your staying toyota. and the t100 rear end is pretty nice in back.
I wouldnt go 44 cause the toy axle can be just as strong if not stonger. An 85 sa with longs would dominate the 44. want real beefy go with a dana60 or ford 9inch with that you could go with a ford 9inch high pinion rear and be set
Old Nov 8, 2007 | 03:05 PM
chimmike's Avatar
best?
D60's or mogs, air lockers, 3 link w/ coilovers
most cost effective?
79-95 yota front axle, allpro/marlin/trail-gear kit, and a lunchbox locker or detroit.
Old Nov 13, 2007 | 05:01 PM
redneckabbott's Avatar
depends on what size tire your gonna be running and where it'll be running really.
Old Nov 13, 2007 | 05:08 PM
mikes19984x4's Avatar
x2 on the Ford 9" or Dana 60, as when you build those up, you'll probably never bust 'em! but yeah, if you had the $ to do it, those unimogs would be AWESOME!!!
Old Nov 13, 2007 | 05:23 PM
Dare44's Avatar
diamond axle that would be the best but expect to drop a ton of money for that
Old Nov 13, 2007 | 07:14 PM
jbraden84's Avatar
I have a93 t100 and looking to do a sas so far i've heard the best option is a chevy dana 44 front axle which is the right width for the spring perches but not sure about the actual axle width. Any ideas out there any info would be very appreciated.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
scottyg486
Jul 19, 2015 05:34 PM
