revolver shackle question?
Old Oct 18, 2012 | 10:41 AM
vtcrawler's Avatar
If I posted in the wrong area, im sorry. I was wondering if anyone uses them in the rear and also if a set that is made for a jeep yj would fit? I ask because I have a chance to pick a set up for$40, thats if they are worth getting and if they will work. Any info would be great, good or bad. Thanks.
Old Oct 18, 2012 | 11:19 AM
rattlewagon's Avatar
What are the measurments for the yj shackle? As long as they are for a 2.5 spring" they should fit.
They are kind of old technology at this point. The double shackle system tends to unload at the least desired times such as side hilling or going down hill.
Old Oct 18, 2012 | 11:29 AM
dropzone's Avatar
Fossilized
i would concentrate on getting the front end of your truck figured out first before tackling the back..JMO..
Old Oct 18, 2012 | 11:30 AM
James Woods's Avatar
^X2, they are not a real sought after item nowadays due to the unloading. The Johnny Joint shackle mounts are a much better design and can be had for $100 from Allpro.
Old Oct 18, 2012 | 11:36 AM
hobbies4life's Avatar
revolver shackles
Having owned an off-road shop and having 20 years experience in the off-road industry, I would not go with revolver shackles if you're planning on doing any serious 4x4ing. If you're just trying to get the lift that they'll give you and stay on the road, that's fine. They're too old of technology, and they'll unload on you coming down a steep grade if you're off-road.
Old Oct 18, 2012 | 03:32 PM
drew303's Avatar
Don't do it. Unnecessary and not safe.
Old Oct 18, 2012 | 09:53 PM
vtcrawler's Avatar
Thanks for your replys, not going with them.
Flying91
45
Apr 11, 2024 04:39 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Shagool22
Aug 14, 2015 12:24 AM
makemusic116
Aug 2, 2015 05:23 PM
