question on sas need help please
About to start a sas on a 92 truck. I was wondering, i want to keep the front tires in the center of the fenderwell. I dont like the look of the front tires under the front bumper, i dont care about approach angles or tires rubbing.
My question is, can i weld the front hanger back from flush alittle to acheive this center look? I know that will put my shackles farther back in the body mount, but thats fine. I know all this needs to be test fitted for shackle angle and everything. I just want to make sure that will most likely put the tires center of the fenderwell.
I plan on using the marlin crawler sas kit with the 5 inch springs. Thanks alot.
Double posted.
https://www.yotatech.com/forums/f152...please-151460/
I saw that you posted over on Pirate too.
im new here and i need some one in seattle who can do a sas on my 95 yota,i already have the solid axel,and my trail gear sas complete kit just came to my home,now i just need the help,or pay some one who can do it right,please send them my way if you know of anyone shydee2shy@yahoo.com or 206 679 9340 cell phone ask 4 nate thanks..
im glad to see you looking for a competent fabricator to help you with your s.a.s...
posting on pirate might not have been the best thing to do they are as friendly over there..
def find a good fabricator who has done a toyota s.a.s shouldnt be hard in seatlle and maybe a few member can point you in the right direction.. what size tire are you eventually going??
Not sure about a 92, but wont you have oil pan clearance issues if you put it back in the stock location? I had to move my axle forward about 5" in order to clear the oil pan and keep the truck low (yes i swapped the pan)
On my '90 I was able to keep the stock 3.0 oil pan with no clearance issues. I have a 4" MC SAS. I kept the same pan after my 3.4 swap... still without issue.
My suggestion would be to do the SAS and just be prepared to get a new pan if you need one, unless someone with your exact vehicle chimes in with what they had to do.
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
TJWilly
Jul 31, 2015 02:05 PM
