need serious help with my frame jigs
Old Nov 25, 2008 | 06:41 PM
blackoutBII's Avatar
i wanted to know if i hole saw them out if i can go straight through and if it will be ok ?
Old Nov 26, 2008 | 04:43 AM
waskillywabbit's Avatar
Theoretically a hole saw would work I guess...but it doesn't sound like it will be fun.
Use some
Old Nov 30, 2008 | 03:58 PM
dirtoyboy's Avatar
yes a hole saw is a pain in the ass but it works fine..will also give you cleaner cuts for lining up the shackle tubes
A right angle drill might help
Old Dec 3, 2008 | 05:44 AM
whorider's Avatar
If I did it again I would use a hole saw, instead of the smoke wrench.
Old Dec 4, 2008 | 02:55 AM
4xJedi's Avatar
The best way is to hole saw the outer walls then torch the inner webbing out. Much easier that way.
Old Dec 4, 2008 | 11:52 PM
swapped89's Avatar
I tacked my trailgear jigs .25inch frm the front of the body mount and used a torch to cut both sides(Iner and outer of each frame rail) but i had 5"HD springs w/V6.
The inner part i cut as close as i could to what i thought matched the outsides. and filed everything to perfection. its worth te time and aggravation to file evrything measure twice. tack once then measure again. no sense screwind up. it will only cost you more in the long run. measure twice
matmattmatthew
10
Feb 9, 2021 04:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
I8URSVT
Apr 17, 2016 03:38 AM
Corvoid
Dec 11, 2015 11:21 AM
sonorn67
Sep 19, 2015 05:39 PM
