my 2wd to 4wd 1986 toyota exta cab turbo build thread!
#61
Go to the parts store and buy a box of engine degreaser,
be sure to get a solovant based cleaner not water. Spray
one can on it and let it sit over night, then hit it with a
pressure washer and blast most of the thik stuff off, then
just repeat the steps till its mostly clean, then find you some
automotive acid for cleaning wheels and such... Spay it down
with that let it sit for a minut or two then spray it off..
Your engine will look new again
#63
#68
after i put the timing chain cover on and started it i found a hairline crack it was leaking from so i tore it down again put a different one on and i guess i tightened the top bolt to tight and cracked that one so i took it off again and put another one on. o ya i sased it to.
#75
so i got my e-locker installed in my v6 housing then installed with some lift springs front and rear. got high steer on (except i still need a ifs steering box) thought i had blow by but just compression tested it 145 psi on all!! whooooo hooooo great for a 240,000 mile turbo motor! man this thing looks so beast o ya i also got some 35/12.5/15 pro comp xts! i have like 50 pics im gonna try to post i hope they dont kick me for to many pics lol.
def interrested to see what it looks like sas'ed
