my 2wd to 4wd 1986 toyota exta cab turbo build thread!
i just parted someones project (extra cab on reg cab frame.) it was a mess all i have to do is throw a 4x4 rear end with some decent springs in and sas the front then throw my w56 trans and top shift t-case in. really i hate wires i dont wanna mess with bobbing a bed on both sides and i really like the wheel base of extra cabs. in my eyes a sas bolt a rear end in and swap a trans seems a lot easyer.
#25
Thats AWESOME!! man..Ive always wanted to do something like that..but ive never had the time and money lol..Great job on cleaning the truck out.. it looks ALOT better now that you've put nice seats in and cleaned out that mess..so you bought it from someone like that inside?
#27
i just threw up a little... i really think i may have nightmares...
i would start soaking that engine in degreaser now so when it comes time you just hit it with the pressure washer, it will prolly need new plugs/wires/cap/rotor any way so just blast it down, then hit it with some acid... mmmm i likey a clean engine..
eck just threw up some more...
#28
#29
#34
pink is 4:10. and purple is 3:42
http://www.4crawler.com/4x4/4R_TechInfo.shtml
as stated here...
i think you would be better off just buying each piece of the truck and putting it all back together.. jk.. you got your work cut out.
as stated here...
#38
so when i put the rear axle in i noticed a few things, the stock 2wd u-bolts fit around a 85 rear axle and act as a u-bolt flip kit but the shock mounts are in the wrong spot(im gonna triangulate the rear shocks later when i put lift springs in). and also this might help some people, i screwed both the 2wd and 4wd rear break lines together and made a nice long one.
