my 2wd to 4wd 1986 toyota exta cab turbo build thread!
Old Sep 9, 2010 | 08:07 AM
99 sas runner's Avatar
i just parted someones project (extra cab on reg cab frame.) it was a mess all i have to do is throw a 4x4 rear end with some decent springs in and sas the front then throw my w56 trans and top shift t-case in. really i hate wires i dont wanna mess with bobbing a bed on both sides and i really like the wheel base of extra cabs. in my eyes a sas bolt a rear end in and swap a trans seems a lot easyer.
Old Sep 9, 2010 | 08:11 AM
i think im gonna pull the rear end today.
Old Sep 9, 2010 | 06:34 PM
rear axle is out. pics a lil later
Old Sep 9, 2010 | 08:33 PM
i cant get my cam to work. ill try again tomorow.
Old Sep 9, 2010 | 09:19 PM
  #25
JDS1992's Avatar
Thats AWESOME!! man..Ive always wanted to do something like that..but ive never had the time and money lol..Great job on cleaning the truck out.. it looks ALOT better now that you've put nice seats in and cleaned out that mess..so you bought it from someone like that inside?
Old Sep 9, 2010 | 09:46 PM
  #26
paynemw's Avatar
bump.... this is a GNARLY thread, def lookin forward to all yer pics and what you can do with that bad boy
Old Sep 10, 2010 | 05:04 AM
  #27
birdduck's Avatar
Originally Posted by 99 sas runner
and a pic of the motor
hahaha ewwwwwww
i just threw up a little... i really think i may have nightmares...
i would start soaking that engine in degreaser now so when it comes time you just hit it with the pressure washer, it will prolly need new plugs/wires/cap/rotor any way so just blast it down, then hit it with some acid... mmmm i likey a clean engine..
eck just threw up some more...
Old Sep 10, 2010 | 09:10 AM
  #28
those are actually the origonal saets! the ugly seat covers saved em, ya thats what she looked like when i got her. money wise i wont spend much i try to stay smart with building stuff. i bught the donor truck for 250 right (including gass) so ill sell the bad 22r for 100 as rebuildable and the trans and t-case for 100, that leaves me at 50 bucks well i already used the blower motor out of the donor sence the turbo trucks was gone (60 dollar part) pluss i get the bed to bob (decent shape) and doors to cut up and make half doors! not including i need the cross member off the donor truck and other little parts here and there si i figure with buying that truck i saved well 150 for a bed, 75 for doors, 20 cross member, 350 on axles ect so ill save around 6-700 bucks using parts (pluss the money for scrapping the frame and cab. i can get a front hanger for around 75 bucks, frame tubes for 8 each and high steer for 200 from a buddy and ill find a decent set of springs for about 200. so if you add that all up i payed 400 for the turbo truck 200 for the donor, just the money i saved with the donor basickly payed for the trucks, i wont be in it much really. see what im sayin lol??
Old Sep 10, 2010 | 09:13 AM
  #29
its got a sweet front main seal leak so when i pull the rad and stuff ill clean her up nice ill probly do a rear main and clutch when i put the trans in or sometime soon and valve cover gasket when i do the front main! shell look good.
Old Sep 10, 2010 | 09:48 AM
  #30
cam worked!
Old Sep 10, 2010 | 09:50 AM
  #31
Old Sep 10, 2010 | 09:57 AM
  #32
Old Sep 10, 2010 | 09:58 AM
  #33
can any one tell me what kind of third member that is? what gear ratio is pink on the pinion? o and if im posting to many pics let me know. lol
Old Sep 10, 2010 | 01:44 PM
  #34
birdduck's Avatar
pink is 4:10. and purple is 3:42
http://www.4crawler.com/4x4/4R_TechInfo.shtml
as stated here...
i think you would be better off just buying each piece of the truck and putting it all back together.. jk.. you got your work cut out.
Old Sep 10, 2010 | 11:30 PM
  #35
got the 85 rear axle in with the stock springs and put the 85s bed on it. pics later
Old Sep 11, 2010 | 04:12 PM
  #36
agusgus3's Avatar
Seems like you got your work cut out for ya, but I can see what your shooting for. Sounds cool, keep the pics coming, happy building!!
Old Sep 11, 2010 | 08:58 PM
  #37
so i got my trans and t-case, new clutch, timing chain set, timing chain cover set, rear main seal set and oil pan gasket today!
Old Sep 11, 2010 | 09:26 PM
  #38
so when i put the rear axle in i noticed a few things, the stock 2wd u-bolts fit around a 85 rear axle and act as a u-bolt flip kit but the shock mounts are in the wrong spot(im gonna triangulate the rear shocks later when i put lift springs in). and also this might help some people, i screwed both the 2wd and 4wd rear break lines together and made a nice long one.
Old Sep 11, 2010 | 09:28 PM
  #39
Old Sep 11, 2010 | 09:31 PM
  #40
4x4jeffyota's Avatar
hahaha thats rad
