Long spline driveshaft issues
I have run into a bit of a snag. I had my driveshaft made using the TG long spline kit and my stock front CV section. It does not even have enough clearance to bolt up at ride height. I know that this setup has been used by others on here with more lift than I have (TG 3" SAS). It is not being limited by the sides of the CV, but rather the lip/rin on the inner "ball" section that it pivots on. Can I clearance this somehow or is there a better fix? I really do not want to fork out the cash for a Tom Woods or High Angle just yet.
See below:
- http://www.4x4wire.com/toyota/tech/cvmod/
You either need to clearance your IFS CV or use a CV from a sold axle shaft. That's it. Don't go turning your knuckles. Mine didn't line up either, I used a SFA CV and it bolted right up.
Here's mine with SFA CV. I'm runninuals now so my angle is much better than this pic.
jasonty
41
Dec 23, 2018 01:00 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
Poncho0206
Jul 10, 2015 06:21 PM
