little torn about full widths
Old Feb 23, 2009 | 02:04 PM
DeepSeaSnake's Avatar
I've got an 87 runner I've been accumulating parts for. Up till recently the plan was to use my 85 front axle with a TG kit or something. I'm now considering full width for a couple of reasons.
First and foremost is 16.5 rims, I can get military 37s with rims all day for less than 50 bucks a tire. Spending money on my rig is almost a fight to the death with my wife so I gotta think ahead about keeping costs low.
Second isn't really one or another but I don't think I'm going to use a prefab kit either way (which eleminates the need to keep the toy front). I'm thinking that cutting the rad support and replacing it with a stout crossmember that can can be used as a spring hanger will keep my COG down and I'm flirting with the idea of running 3/4 elip for the front end and building a little goofy front anti wrap bar. Figure I'd get better than the 10" of travel most people report with the kits.
So I'm thinking an old broke down chevy could run me as little as a few hundred bucks for some 1tons and then I could run hummer wheels and i'd be doing the suspension from scratch anyways. The only questions left unanswered would be steering and drive lines. I figure adapters may work for the Drive lines and steering, who knows i'd just piece it together when the truck is sitting in front of me.
I guess this would all be mute if I could find an affordable source for meats in a 15" rim.
Old Feb 23, 2009 | 02:29 PM
crolison's Avatar
Well you can recenter hummer rims, or get 6lug 16.5 rims. You can get drive line adapters for them so you can run toy dshafts.
Nothing wrong with wanting to run full widths. dana 60 and a 14bolt would be a good combo.
Old Feb 23, 2009 | 02:51 PM
6 lug 16.5 don't exsist anymore, it would solve alot if they did. Neither do the old spacers that would convert 6 to 8 lug
Edit: Someone prove me wrong
Old Feb 24, 2009 | 04:32 AM
WFO's Avatar
WFO
If you can get a 1ton front axle for a few hundred do it!!!
As for steering do a search.. There are several companies that make kits for those axles.
Dont expect this to be the less expensive route.
Old Feb 24, 2009 | 06:15 AM
I'll investigate the steering options, as far as axles craigslist is full of beat down fords with 44s and 9s most can be had for like 500 bucks and if you can find one with a 460 or 400 you can get almost that much back out of it.
I'm gonna look into recentering :shrug
Old Feb 24, 2009 | 06:41 PM
yotaman's Avatar
Don't tell Summit Racing 6 lug 16.5" wheel aren't around anymore. There are like 20 differnt kinds on there website.
Here's a link to some $65.00 ones.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=USW-706960&N=700+4294923107+4294923105+4294793321+4294 755953+115&autoview=sku
Old Feb 26, 2009 | 01:13 PM
well then I'll call em when I get off and see whats up. Thanks!
Old Mar 2, 2009 | 11:17 PM
yotaofdoom11's Avatar
60 14 is and unbeatable combo. steering; axle side do everything full width from offroaddesign.com and you will have no problems, frame side just use your favorite yota offroad supplyer, all you'll have to make is a custom draglink
stanz
Oct 30, 2015 10:33 AM
Swampwalker
Oct 12, 2015 09:49 AM
Project90
Sep 24, 2015 11:40 PM
toyotasaurus
Sep 24, 2015 03:30 PM
mat
Sep 17, 2015 11:18 PM
