Kycrawler's (low) SAS
Old Jun 25, 2011 | 06:29 AM
  #61
DIRTY89RUNNER's Avatar
Looks awesome nice work.
Old Jun 30, 2011 | 08:11 PM
  #62
874runnersr5's Avatar
dude awesome build, how did you mount the front hanger? flush? how about the rear shackle holes?
Old Jul 1, 2011 | 03:33 AM
  #63
KYcrawler's Avatar
Thanks.......The front hanger is made to mount flush directly below the factory crossmember upfront. Mine is just pushed a little forward. The shackle tubes I just torched the holes out and welded the tubes in place.
Old Jul 1, 2011 | 02:37 PM
  #64
gotcha, it sits well
Old Jul 24, 2011 | 04:02 PM
  #65
KYcrawler's Avatar
37s will fit w/RUF
I had my doubts, but they do not rub anything except the springs at full lock. I'll loose a little bit of steering but the radius was bad enough already. I can live with it considering all the benefits of the Irocks over the MTRs. Can't wait to try them out.
Old Jul 24, 2011 | 04:16 PM
  #66
MaK92-4RnR's Avatar
Hey man, you still running stock leaf packs up front? how are they holding up?
Old Jul 24, 2011 | 04:53 PM
  #67
fork's Avatar
Originally Posted by scuba
HUH. Thanks for the info 4Crawler! I might have to do that (grind grooves in the lower gusset) with my axle that I have sitting in my garage.
x2. if i ever get around to it
Old Jul 24, 2011 | 04:55 PM
  #68
KYcrawler's Avatar
Yeah, still running stock pack. I'll leave them till they break or till I link it this winter.
Old Jul 28, 2011 | 03:13 PM
  #69
MaK92-4RnR's Avatar
what's making you link it? dont like the leaves?
Old Jul 28, 2011 | 03:53 PM
  #70
KYcrawler's Avatar
1:In the rear I am planning to cut most or all of the bed off behind the cab, tube it and use only half of the split bench seat and center the seat. I want to keep the wheel base (104") so the portion of the leaf spring behind the axle poses a problem.Also the rear does not flex nearly as good as the front.
2: In the front, my approach angle kind of sucks because of the spring hanger. It's not as bad as it would be with front springs instead of rears up front but I would rather not take angled approaches at obsticales if I can help it. Links would be better but the rear links and cage will come first
Old Jul 28, 2011 | 05:25 PM
  #71
MaK92-4RnR's Avatar
Oh ok. Yeah, I've considered SASing my truck but I want to keep it low. 33-34" tires max. would you recommend your setup? i dont have a bodylift either, so im sure it would sit a bit lower.
Old Jul 28, 2011 | 05:40 PM
  #72
KYcrawler's Avatar
Yeah, I like my set up, it's just progressing and I'm figuring out the pros and cons of it as I go. Don't get me wrong, my truck is far more capable than it was when it was IFS. I just like to tinker ( it's half the fun). This set up would be great to run 33s
Old Jul 28, 2011 | 05:47 PM
  #73
MaK92-4RnR's Avatar
sweet. Do you think I could run stock leafs with an add a leaf and stock shackle? should give just about the same lift as you have now, correct?
Old Jul 28, 2011 | 06:17 PM
  #74
KYcrawler's Avatar
Don't see why not.
Old Jul 28, 2011 | 06:19 PM
  #75
KYcrawler's Avatar
Oh and really not sure on the amount of lift. I guess as far as suspension it would depend on the add a leaf
Old Jul 28, 2011 | 06:31 PM
  #76
MaK92-4RnR's Avatar
makes sense. i would just need to figure out how to leaf the rear end to make it match the front... im thinking a TG rear leaf kit would be sufficient
Old Jul 29, 2011 | 02:55 PM
  #77
KYcrawler's Avatar
My buddy has 63" Chevys in the rear of his and it sits the same height as mine. If I didn't want to bob mine, that's what I would do. It flexes well too.
Old Aug 1, 2011 | 08:01 AM
  #78
tlrskunk's Avatar
I'm doing 63" chevy's in the back of my 4Runner. I can't wait to get rid of the stock 4 link.
Old Sep 12, 2011 | 05:33 PM
  #79
KYcrawler's Avatar
Little update (build thread?)
At this point this thread maybe in the wrong section (SAS? / Build thread?) but with that said I have continued to hack away and figure out which direction I'm going with this pile. Anyway I got started on the cage and decided to go ahead and eliminate the rust in the rear body panels by simply taking the sawzall/cut off wheel/plasma to it. It's not done but I figured throw it out there and maybe get some suggestions.I've got an idea of how the back will be caged and I will be adding sheet metal around the rear passenger area from the floor/rocker up to bed rail height. Ideas are welcome though.
This is what I've got so far.
Old Sep 13, 2011 | 08:54 AM
  #80
stock as possible's Avatar
Looking good. Are you doing a cage rear? That's an interesting way to tie the exo into the Addicted bumper.
