Kycrawler's (low) SAS
Old 02-16-2011, 06:23 PM
KYcrawler's Avatar
Originally Posted by 9164RUNNER
Nice build. Can't wait to do my runner! I wanna see some flex.......
Flex coming soon......I still have some things to do. I need to get an extended brake line for the rear, change fluids in the transfer cases, modify the front shock hoops and bolt up the front drive shaft. I did finish the rear shock set up and get the rock sliders on but I need to finish painting them. I'll post pics by the weekend.
Old 02-16-2011, 06:38 PM
KYcrawler's Avatar
Originally Posted by Taxman13
how much did it cost to do it all
$250 for the '85 axles ( had to buy both because the seller would not seperate)
$200 for the sky front hanger kit
$0 for the springs ( buddy went with 63" chevies)
$320 for the bilsteins
$55 for the ss braided front brake lines
$60 for the knuckle service kit
$180 for the high steer (craigslist)
$65 for the u bolt flip kit
$65 for the flat pitman arm
$20 for the steering box re-location kit
$65 for the shock hoops
total of $1340
-$250 for bj spacers, pro-comp shocks etc. from IFS lift
=$1090 give or take
Gotta pay to play.
Old 02-16-2011, 06:57 PM
KYcrawler's Avatar
Home brew rear shock hoop
Ended up with more angle than I wanted (about 39-41*)
I'll get some pics of the rock sliders as soon as I get them painted.
Old 02-16-2011, 07:11 PM
87hillbillyoter's Avatar
wow looks great man!
Old 02-17-2011, 10:26 AM
  #25
KYcrawler's Avatar
Thanks, it's been a fun process. Can't wait to see what it'll do
Old 02-21-2011, 04:23 PM
  #26
KYcrawler's Avatar
No real action shots yet but some poser flex.....I don't have anything around here to max it out but there is about 2 1/2" of up travel and about 6" of down travel left.
I also got the sliders done over the weekend.
Old 02-21-2011, 08:43 PM
  #27
4Crawler's Avatar
Originally Posted by scuba
You need square Ubolts under the drivers side.
These look like round.
I cant tell you how many SA's I've seen with round u bolts under there. Looks like a death trap.
I actually prefer the round u-bolts on the front axle, both sides. I have seen too many of the square u-bolts snap under the front axle. And guess where they snap? Right at the square bend, that point is highly stressed and it'll let go.
What I do with the round bolts is to grind a slight groove into the leading and trailing corner of the axle gusset to hold the bolt in place and give it a more rounded place to sit. Works fine for me and have not had a single round u-bolt fail on my truck and I've been running the same set up front for about 12 years now (since I had a square one from AllPro fail on me):
Old 02-21-2011, 08:51 PM
  #28
scuba's Avatar
HUH. Thanks for the info 4Crawler! I might have to do that (grind grooves in the lower gusset) with my axle that I have sitting in my garage.
Old 02-21-2011, 09:13 PM
  #29
VANCE164's Avatar
I'm just curious did you do anything to the packs for RUF or did u just use them stock with the shackles?
Old 02-21-2011, 09:29 PM
  #30
4Crawler's Avatar
Doesn't take a lot of grinding either, this is before:
And after:
I think it took 2 tries to get the grooves ground right, first time just ground a little where there were marks left from the u-bolts on the gusset. Then after a year or so, pulled them off and re-ground the grooves where you could again see the marks where the u-bolts sat in the grooves.
And that string hanging down has a magnet on the end to tip traffic light sensors which I have trouble with around town.
Old 02-22-2011, 03:41 AM
  #31
KYcrawler's Avatar
Just a stock pack for now until I give it a shake down. I would like to get a feel for the pack before I just start adding random leafs. I assume I will need to add a leaf or two at some point. From what I can tell so far I have no clearance issues, but I'm not sure the stock pack will be stiff enough.
Old 02-22-2011, 04:19 AM
  #32
KYcrawler's Avatar
That is a pretty good idea. Now that you say it, I could see how the square bend could be a weak point. Thanks for the advice.
Old 02-22-2011, 09:05 AM
  #33
VANCE164's Avatar
Thanks i thought I was just a stock pack but wasn't sure I'm going to be doing a RUF on an 82 in the near future and am just trying to get an idea of what to do with the packs and I like how yours sits. Nice build and thanks again
Old 02-22-2011, 04:52 PM
  #34
KYcrawler's Avatar
Thanks man, I like the height myself. It turnned out exactly how I wanted it.....Low. I'll let ya know how it does on the trail as soon as I can. I'm hoping to get it out on the 6th at a local OHV park. I'll post pics later.
Old 03-07-2011, 02:58 PM
  #35
KYcrawler's Avatar
Little fun from sunday
[youtube][/youtube]
Hope the video worked. It was MUDDY at the offroad park Sunday, so I really did'nt get to do a whole lot. All in all the truck did well and so far I am pleased with the swap so far.
Old 03-07-2011, 02:59 PM
  #36
KYcrawler's Avatar
Guess it did'nt work..... I'll try again.
Old 03-09-2011, 12:17 PM
  #37
LGcrawler's Avatar
nice vid! and the builds lookin sweet
Old 03-09-2011, 02:08 PM
  #38
VANCE164's Avatar
Nice video and looks like it flexs well!
Old 03-09-2011, 04:13 PM
  #39
KYcrawler's Avatar
Thanks guys, It rained from friday night through saturday and did'nt stop til about 4 in the a.m. sunday. I did'nt care for mud before and now I hate it. It was a childrens cancer run and I had not taken my truck out with the new mods yet, so I went anyway. At least the money went to a good cause and there were a lot of trucks, 4wheelers, buggys, side by sides, etc.
couple of pics.....
and a little flex.....
I still did'nt max it out or lift a tire, but like I said it was muddy and not a lot to crawl around on in the mud.
Old 03-11-2011, 08:10 AM
  #40
stock as possible's Avatar
That does look really good for a stock pack up front. Are you having any interference/binding with the hi steer or drive shaft?
Quick Reply: Kycrawler's (low) SAS
