Just Plain Stuck
Old Jul 20, 2010 | 09:43 PM
Yotakid23's Avatar
Just Plain Stuck
Hey so im getting ready to do a SAS to my 2nd gen. I bought two partially good axles to make 1 good one overall. My problem is on my axle thats good from the knuckles out, its got what looked like just some surface rust but I cant for the life of me get the steering linkage off the top, or the little caps off the bottem. All the nuts came off no prolem, and I've soaked them in tons of penetrating oils but they just wont buge. Anybody got some trick that makes this easier? It's really slowed me down
Old Jul 21, 2010 | 06:23 AM
Tofer's Avatar
Sponsor
did you get the cone washers out? put the nut back on the stud a couple turns and hit it gently with a hammer the cones will pop up. once the cones are out it'll come off easy.
Old Jul 21, 2010 | 11:30 AM
Yotakid23's Avatar
yeah I got the cones out, and thanks I will try that. Sorry if it was a newb question
Old Jul 21, 2010 | 04:04 PM
4Crawler's Avatar
Might be someone in the past forced the steering arms into some knuckle bearings and you might need a thin pry bar or a BFH to force those arms and caps off. I've run into that once, basically had to destroy the bearings to get the arms off. After that, I take care to check the bearing fit on the arms and if they don't slide on easily, I lightly file/sand down any high spots until they do.
Old Jul 22, 2010 | 02:15 PM
Yotakid23's Avatar
Thanks for the advice, Ive got them off now and it actually took a little bit of both methods you guys said. It's obvious someones been into this axle before, the parts all seem to be ok, but I think youre right about somebody forcing it all on at one point, cuz that was ridiculous
Redeth005
Jun 28, 2018 08:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
spiewaker
Dec 16, 2015 01:10 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Obmi
Sep 24, 2015 08:10 AM
