i messed up
Old Mar 18, 2007 | 07:12 PM
Toy-SkiTzo's Avatar
i messed up
my freind came by today to weld a couple things for me and i didnt notice this until after he finished
left
right
i messed up
Old Mar 18, 2007 | 07:15 PM
tc's Avatar
tc
Measure twice, cut/weld once!
Old Mar 18, 2007 | 07:18 PM
91TPU's Avatar
ditto
Old Mar 18, 2007 | 07:24 PM
WATRD's Avatar
Plate them both on both sides and start over. And for goodness sake, turn up the heat on that welder a bit!
Old Mar 18, 2007 | 07:38 PM
waskillywabbit's Avatar
Talking
Yep, it'll take some work, but fixable...and find a better welder (friend)!
Old Mar 18, 2007 | 07:47 PM
KyleT's Avatar
what is wrong with them???
Old Mar 18, 2007 | 07:52 PM
yotasavg's Avatar
they aren't even. the right one is way farther back than the first....or maybe you meant the welds....jk!!
Old Mar 18, 2007 | 07:58 PM
Toy-SkiTzo's Avatar
ill probbly do somthing similer to this
http://www.pirate4x4.com/forum/showt...524775&page=11
Old Mar 18, 2007 | 08:31 PM
Elvota's Avatar
That's a bummer. I guess you didn't have the jigs that come with most of the kits?
After I had mine welded in, I had an idea that might be helpful for your fix. In my opinion, it can be difficult to get the holes all lined up even with the jigs. Keeping everything in the right position once welding starts doesn't make things any easier.
I thought it would make sense to pre-weld the bushings to a plate. It would look like a "T" when done. One would have to match the angle of the frame to keep things parallel, but then the actual frame holes would not have to be that precise. One could actually have some room to move (fore and aft) and the plates (being exactly the same) would keep things aligned.
Like this:
Position new "T" part into frame. Bushings would be in exact position and wouldn't rely on a jig hole or the precision of your hole saw/ plasma cutter/ torch/ BFH.
As such:
Then place your second pre-drilled plate on the inside and weld the bushing to it, as well as welding plate to the frame.
TaDa:
My thought was all the precision fab work could be done in a more comfortable and precise work space instead of upside down and under the truck. Also, the plates would add significant strength and allow both sides to align perfectly.
It would be nice if one of the pre-fab kits came with bushing already setup like this so you could make a much rougher frame cut yet still have a more accurate and strong finished product. I am sure a production fab company could really get the angles and plates to match perfectly and make the home fab step that much easier.
Old Mar 19, 2007 | 09:15 AM
Toy-SkiTzo's Avatar
that is a good idea i think in goin to try that
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
EVars
Sep 29, 2015 02:06 PM
Boomer8404
Sep 24, 2015 01:12 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
