frame tubes
Old Feb 23, 2009 | 05:33 PM
mudpunisher's Avatar
frame tubes
what size DOM do i need to use the all pro bushings for their front spring hanger kit. i dont know the outside diameter of the bushings or inside diameter of the tube. TIA
Old Mar 3, 2009 | 11:33 AM
bump. still need this info
Old Mar 3, 2009 | 03:02 PM
4Crawler's Avatar
ID is the same as the OD of the spring bushings, that is 30mm (~1-3/8"), so find a wall thickness and OD that gives you that ID. I think the stuff I used was 1.5" OD and 0.160" wall thickness, or if you can find metric, 38mm OD and 4mm wall thickness would work.
Old Mar 6, 2009 | 02:46 PM
thank you! thats gonna be a fun size to find
justdifferentials
14
Jun 11, 2017 08:36 PM
indawire
Nov 29, 2015 05:05 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
old87yota
Sep 9, 2015 12:39 PM
dguzzi
Sep 3, 2015 08:48 AM
