eliminating the lspv
Old Nov 14, 2008 | 05:55 AM
cherokeechief79's Avatar
mine is on a 94 v6 runner.sky mfg says its quite involved on the v6.lines go up to a box that he says keeps the steering straight in a panic stop.there are also power steering lines going into this box.they said i really need a completye setup from a 4 cyl rig????? is it really this involved to eliminate it?
i have had it secured in one position for over a yr now so its not even functional.
Old Nov 14, 2008 | 08:06 AM
4rnr's Avatar
Is it leaking? why do you want to remove it. I cut my load sensing arm and just positioned it in a way that worked well. Then it started leaking. I couldnt find another good one in a junkyard, so I just put a union t in its place. works fine. Yes yes, it "could" make the rears lock up in the rain. but my drums CANNOT lock up my 120lbs wheel tire combo...
If you want to do it right. just remove the abs unit on the pass frame rail. then just run the rear line directly to the union t in the back. spend 50$ on a manual proportioning valve from summit and install it at the master.
Old Nov 14, 2008 | 08:25 AM
is the abs unit the thing with the ps lines going into it also?i want to remove it because i too have mine tied up in one position and i just swapped to leaves in the rear.i would like to just do without it so i dont have to fab a mount for it.
Old Nov 14, 2008 | 08:33 AM
4rnr's Avatar
Yup thats it.
Old Nov 18, 2008 | 05:36 AM
ok i think ive gathered enough info to do this.im gonna use a wilwood man prop valve.the only thing im still a bit confused on is that most of the writeups ive seen were without abs brakes.i have this but its doesnt really work since i replaced my 3rd member in the rear.im not at all concerned about keeping the abs at all im just wondering if i can still just plug the return line up front and plumb in the manual valve on the feed line in the rear.or will i have to remove the whole abs box itself?
Old Nov 18, 2008 | 04:44 PM
Kiff's Avatar
what can we do about that thing that the steering lines and brake lines go into up front? it takes up so much room, I want to clean out as much of the engine bay as I can.
Old Nov 19, 2008 | 10:03 AM
4rnr's Avatar
You dont have to remove it, you can do what you have posted.
Take it out and run the PS pump directly to the steering box and run the brake line directly to the rear.
Old Nov 19, 2008 | 10:37 AM
i thought (from reading on other forums about it)that i might be able to get a higher pedal without it.my pedal has always been low even though im sure ive got all of the air out.ive bled about a gallon thru thru-out the years and have always had a low pedal.with the eng off the pedal pumps right up to the top hard as a rock but once started and the booster comes in it goes right down.
Old Nov 19, 2008 | 11:17 AM
4rnr's Avatar
Mine does the same thing. Mine is still in the truck though im not sure if its disconnected...Ill have to check.
If I would have thought of it during my motor swap I would have pulled it. I can still pull it but its low on my priority list. I suggest pulling it.
Old Nov 19, 2008 | 01:23 PM
tc's Avatar
tc
I have ABS and that's what I did and it works fine.
Old Nov 20, 2008 | 02:40 AM
thanks for all of the info!!
now just waiting for parts to arrive.
XtraCab
Apr 12, 2020 05:25 AM
Scatterbrain
Sep 27, 2015 08:24 AM
87toy pickup
Sep 7, 2015 06:42 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
