Did you shim your 5'' HD trail gear sas
I have a Trail Gear heavy duty 5'' SAS front end and my pinion angle is horrible. (5'' shackles came with the kit)
If you have this kit under your truck and put SHIMS on the axle to fix the pinion angle please let me know what degree of shims you used.
Generally up front you would only want to shim as needed to correct any caster angle issues:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
At least if you plan to drive the rig on the street at all.
To correct the pinion angle, you need to do something like this:
- http://www.4x4wire.com/toyota/tech/rotated_housing/
or install a high pinion front diff or install dual transfer cases, both of which lessen the angle on the pinon and drive shaft.
And case in point, I have about 4" of front suspension lift, plus the t-case is raised 2", axle moved forward ~2.75" from stock, dual cases, and a high pinon front diff and I have no shims on the front axle and have a good caster angle and an almost perfect (i.e. near 0 degrees) pinion angle.
im having that problem right now!! thank god i thought i was the only one...so if we cant shim....what do we do??? short of dual cases and high pinion
be carefull shimming. the closer you get to 0* caster the higher the risk of a "death wobble"
The best way to fix this is a cut and turn. set your pinion angle to whatever helps you sleep and night and set your knuckles to around 6-8* of caster. I have about 7* of positive caster, before I was about 3.5* of positive and I had a wobble @ 35mph where I felt like the wheels were gong to come off
i had my cv turned into a high angle u-joint and that also helped the driveline. decreases the angle at the pinion cause it doesnt stick out as far as the cv did from the transfercase
Flying91
45
Apr 11, 2024 04:39 PM
XtraCab
Apr 12, 2020 05:25 AM
Backcountry411
Jul 24, 2015 08:06 AM
