dana 44?
Old Apr 23, 2008 | 02:06 PM
4x4YOTA's Avatar
dana 44?
ok so I want to sas my truck and I found a pair of front and rear dana 44 axles both with 4.56 gears the rear has an ez locker and the front has an ez locker as well but no knuckles or shafts he is asking $250 for both are they worth it ?
Old Apr 23, 2008 | 03:17 PM
AxleIke's Avatar
Sure.
Sounds like a good deal. Sucks you just got new tires though, they'll look goofy on a huge truck.
Old Apr 23, 2008 | 05:13 PM
4x4YOTA's Avatar
well then thats my next question what is the lowest I can go with a SAS
Old Apr 23, 2008 | 05:18 PM
AxleIke's Avatar
3" springs is the absolute minimum to clear the steering.
Usually that is 4-5" over stock.
Old Apr 23, 2008 | 07:51 PM
4x4YOTA's Avatar
ok cuz I dont want to be any higher than 3-4 over stock is that possible at all
Old Apr 23, 2008 | 08:03 PM
AxleIke's Avatar
If you do it yourself, you MAY be able to go lower.
Its been done. However, I'm fairly sure those who did it had a different steering set up.
Good luck with the project. Out of curiosity and not to be rude, but you just bought a bunch of IFS stuff. Have you wheeled that yet? If so, what was so awful about it that you decided to cut it off?
I will look forward to your build process. Hopefully you do it the correct way with longs and a front locker. If not, you will have just spent a bunch of money to get stronger steering.
Old Apr 23, 2008 | 08:06 PM
4x4YOTA's Avatar
no I just have always wanted to do a sas and I used to have an 1982 toyota 4x4 setup for crawling and I miss it my IFS is nowhere as good as my 82 was but its not bad I do like the ride I just found these axles and thought I would ask I mst likely wont cuz lake of funds
Old Apr 24, 2008 | 03:17 PM
bigarms23's Avatar
those are great axles so buy them and for like 150 dollars you can buy a set of welderbuilt knuckles
PNWrider
Oct 30, 2015 08:14 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Cebby
Feb 20, 2007 11:33 PM
1WiCkEd_RuNNer
Mar 21, 2004 03:43 PM
