E-Locker in front
Old Mar 15, 2008 | 07:52 PM
ugeazzbass's Avatar
E-Locker in front
installed an e locker from an 03 taco v6 in the front of my sas conversion.
im changing to 5.29's. what the hell kind of gear do i install (reverse cut?)
i have '80 p/u front axle, '88 4run rear.
Old Mar 15, 2008 | 07:59 PM
86tuning's Avatar
Just a regular v6 gearset. Front and rear carriers and gears are interchangeable.
The only reverse cut gears are for high-pinion applications, so if you were using a land cruiser (fj40 thru fzj80) front diff, then yes.
Old Mar 15, 2008 | 08:03 PM
ugeazzbass's Avatar
thank you!!! by the time i get off of work, no body to talk to at retail stores.
Old Mar 16, 2008 | 07:08 AM
Marc P's Avatar
I just put one in mine. Just make sure you get the right master install kit for the gears and take your time...
Here is the link to my install
http://www.ultimateyota.com/index.ph...35.0;topicseen
Old Apr 25, 2008 | 09:00 AM
toyyota's Avatar
I highly recommend you invest in the motor cover, Marlin sells for about $50. When you hit a rock with your E-Locker that motor sells for about $550. from Toyota. I tried the cable conversion kit, good idea but didn't work for me.
Old Apr 26, 2008 | 03:40 AM
Blizzard's Avatar
Marc, did you have problems with the motor touching the springs? I suppose the problems will be the same in the High Pinion E-Locker as the motor is in the same side...
I don't have any locker in the front yet, but I've a HP and I think I'll be changing it in the future for a HP E-Locker.
David
Old Apr 26, 2008 | 05:44 AM
Marc P's Avatar
I did have to change 2 bolts so the flush mounted, and had to file the housing just a little to get the u-bolt to clear.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
Sr5crawler
Jul 31, 2015 12:32 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
AaronM
Jul 8, 2015 07:15 PM
