Anyone had brake issues after SAS?
We got done with our SAS this weekend and when we went to bleed the brakes i cant get any pedal at all. The pedal will go to the floor even after pumping several times and is even easier if the truck is running. Replaced master and checked out the booster. All the lines are tight and unrestricted. The whole system has been bled along with the master cylinder. BTW this is an 86 pickup with the TG 4" IFS Elimininator kit and Classic Rear.
I had the same problem after my SAS. I wasn't able to get the brakes tight enough no matter how much I bled them. Fortunately I lived basically right across the street from a service place so I drove it over there and had them power bleed it and it took care of the problem...
Yeah I used the 86-87 calipers on the rotors that came with the kit, no real problems (maybe a little pulsating but I probably need to machine the rotors is all).
i have to pump my brakes a bit to get full stopping power, just slammin on them will take a while to stop, but i have learned to drive with them.
what i think the problem is, is that there is not enough fluid in the system to compensate for the extended brake line, when the brake lines are extended it requires more fluid to fill more brake lines.
so a fix, that some have done is install a larger brake master cylinder, to have more fluid flowing in the system. marlin sales a larger one, and i belive its off an fj80 or something.
Someone correct me if I'm wrong here...
that makes sense, i had it a bit wrong, when the cyl is full there is enough fluid to fill all brake lines and the resivour, but with a larger master cyl, with a larger piston like the fj80 cyl is able to push a higher volume of fluid for increased braking power.
heres the one marlin sales
http://www.marlincrawler.com/htm/brakes/mcylinder.htm
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Johntom240
7
Jul 13, 2015 12:18 AM
