AFter SAS, more lean to one side than before...
Well, before the SAS, I noticed some passenger-side lean.
Since the SAS, it's gotten worse. I'm wondering if it's because of the gas tank? Anyways, I look under the front of the rig, and it's obvious that the pass. leaf spring is compressed more than the driver's side.
Any ideas?
Any ideas?
mine does that exact same thing, passenger side lean, ive seen this question before and ive asked it myself, most of the guys here say that it is because the springs are so soft and runners are relatively heavy so they just lean.
Either way, it's noticeable that the pass. side spring is compressed more...I'm guessing there's just an unbalance in weight distribution side to side in the truck or something? Fuel tank?
Is it a "gangsta lean" by any chance? Maybe the SAS has just given your 4Runner some street cred.
Mine leaned a bit at first, but then the springs got worn in and it sits even now. I'd recommend wheeling it a bit and see where it ends up. If still leaning PS, then consider a spacer if you find the lean problematic.
probably just cheap springs in combination with uneven load or something. if it bugs you, take your spring packs out, lay one on the concrete, mark the concrete and lay the other over the marks to see if they are different. if they are not, you know where your problem is...either different spring rates or uneven loading.
if you dont care that much, just get used to leaning your head slightly the other way....
oh I know it's the lean, I mean it's clear that the pass. spring pack is compressed more than the driver's side. I'm wondering if there's just a spring rate difference between the two packs. I don't want to do like a helper leaf though because I think making the different spring rates between sides could wreak havoc.
There is more weight on the passenger side. Couple of notable items:
- Battery, gas tank and front-drive section of the transfer case.
So that side of the suspension will settle first as the springs break in. Over time, they may level out. The other option is to swap springs side-side once they are done breaking in and that should level things out.
first off Quote:
Originally Posted by Big_Denny
i have been trying to find the dip stick for my rear differintial and just can not fid it is there a posibilty that the previous owner removed it? or lost it? he seemed pretty dumb and didn't know about wheeling "
thats the funniest i heard ever in my this week...but back to point...
would parking two tires on da curb while the break in help to even load while they're wearn in?
