98 T100 Axle Swap Questions?
Old Jun 3, 2014 | 06:19 AM
swinkjoe26's Avatar
What do i need to convert my 98 t100 to straight axle? What are the best parts and prices on those parts? Thanks
Old Jun 3, 2014 | 07:25 AM
rattlewagon's Avatar
Short answer is you need an axle and the parts to hang it. There really isnt a "kit" for a t100. Youll need a wider axle than a mini truck axle. FJ 80 maybe? Or a pass drop Dana 44 or 60? Whats the WMS on a t100? Maybe some one whose done one will chime in.
Sky t100 hanger and shackles.. http://www.polyperformance.com/shop/...n-p-31337.html
From the link above.
Expect to spend 2-3k on getting the axle under there buying pre fab pats. Can do it for quite a bit cheaper making your own.
Heres some more info. https://www.yotatech.com/forums/f152...00-sas-202607/ Check out post 17
Old Jun 3, 2014 | 03:43 PM
swinkjoe26's Avatar
98 t100 sas
Does this kit come with everything except the axle?
Old Jun 3, 2014 | 04:37 PM
CJM's Avatar
CJM
Wagoneer axle will work well, diff is on the correct side I recall and wms is close to what ya need. Its a D44 too.
Old Jun 3, 2014 | 07:08 PM
scuba's Avatar
WMS on a t100 rear is 67". I don't recall waggy axles being anywhere near that and FJ80' s are around 63.5
I'd say get a built diamond axle instead of trying for a junkyard Dana match
Old Jun 18, 2014 | 11:46 AM
No that kit is just the front hangers and shackle. Youll still need... axle, steering, springs, breaks.. blah blah blah
Old Jun 19, 2014 | 05:06 PM
Killer B's Avatar
Economically you could use an 80 series with all of the 80 series suspension parts (front arms, spring buckets, shocks etc) the rear axle on the T100 is 66.75 and the 80 series front is 63'5, use spacers in front to get you in the ballpark (your front IFS is 65 inches so a 3/4 inch spacer up front will put you back to stock width) all of the aftermarket support for the 80 series gives you choices in spring rates, height, shocks etc.
I am swapping in a complete FJ80 front suspension under my T100 when I can find the time.
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
taller1
Jul 16, 2015 03:00 PM
Coreyr384
Jul 10, 2015 11:13 AM
