93 runner 1 ton'd
Old May 10, 2008 | 07:15 AM
  #41
smashmetal's Avatar
Diff cover hydro assist mount.
Old May 10, 2008 | 07:18 AM
  #42
smashmetal's Avatar
High steer tie rod, 1.75x .375 wall tubing.
[IMG]http://i214.photobucket.com/albums/cc160/smashmetal/93%20Toyota%204Runner[IMG]
Painted and all mounted up.
Old May 10, 2008 | 07:23 AM
  #43
smashmetal's Avatar
Adding a cooler for some more fluid capicity.
removed some of the fan shroud so the hydro lines have a place to go through.
Just enough room.
Old May 10, 2008 | 09:23 PM
  #44
fillsrunner4's Avatar
looks like things are coming together nicely. those T/c mounts look real good. I might just have to check them out if Mine fail on me.
Keep it up
Old May 11, 2008 | 05:53 AM
  #45
smashmetal's Avatar
Keep it up
The Transfer case mount was $87 shipped, so even if your old one dosent fail it's still woth the upgrade. Not to mention it's much cheaper that the Marlin T/C mount and twice as strong.
Old May 11, 2008 | 05:57 AM
  #46
smashmetal's Avatar
Finally got a chance to get a good flex test on it, I need to get the spring rates abit more even. The rear's are way softer then the front's and it's time to take some sheet metal off the back quarters fo some tire clearance.
Old May 11, 2008 | 07:36 AM
  #47
dirtoyboy's Avatar
Pretty sick looking...Do you use the stock reservoir for the hydro?
Old May 11, 2008 | 08:52 AM
  #48
john rumbo's Avatar
very nice rig. i like the hydoasist can you pm me with where to find complete kit and price thanks alot
Old May 11, 2008 | 12:07 PM
  #49
smashmetal's Avatar
The resivor I had on my stock Toyota V6 power steering pump was plastic so there was little I could do to mod it. Lucky for me I had a friend that just removed the power steering pump from his 88 V6 4runner. For some reason the early modle V6 power steering pumps used a steel resivor, three bolts and it just pulls right off the pump. That is the resivor you see pictured above, much easer to mod steel than plastic.
Word of advise thought! if you wanna go the same rout as I did make sure you add a large cooler to the system. The tiny resivor dosent support enough fluid capicity the make the system work corectly. It took me a couple of days to find out why I couldent get the hydro assist to work
Old May 11, 2008 | 12:14 PM
  #50
smashmetal's Avatar
Your in luck I have a much more detailed thread here that list all the prices and part #'s I used to put it together. It starts near the bottom of the page. If you need any more info just let me now, this should awnser most of your questions.
http://www.offroadfabnet.com/forums/...?t=925&page=10
Here are a few more resources I used to help get started.
http://www.pirate4x4.com/forum/showthread.php?t=630765
http://www.pirate4x4.com/forum/showt...+steering+pump
Old May 11, 2008 | 12:15 PM
  #51
Wish I found the mounts before I bought mine but oh well it works for now
The Runner looks sick and plenty built to go start tearing into things
Old May 12, 2008 | 06:27 PM
  #52
smashmetal's Avatar
Fore sure! Im trimming the rear sheet metal a bit to keep the tires from getting cut too piss. I think I gotem where I want them, I just need to give it another flex test to make sure I got it all.
Stupid fuel prices are kinda taking the fun out of everything these days.
Old Jun 26, 2008 | 08:41 AM
  #53
INFERNAL's Avatar
Wow,looking good man nice work for sure!!!
Old Sep 14, 2008 | 06:36 AM
  #54
smashmetal's Avatar
Been a while since I threw down some updates!
Finally got my hydro assist working correctly, just need a decient sized resivore!
Started getting the winch mounted, Trail Gears winch mount serves as a good base. There is roughly about 3/4" of steel on the front of the frame now!
Old Sep 14, 2008 | 06:39 AM
  #55
smashmetal's Avatar
Had to rebuild the king pins real quick!
So I could do this! I also learned that by putting limiting straps on the rear suspension finally made the front springs start working.
Old Sep 14, 2008 | 06:43 AM
  #56
smashmetal's Avatar
Got a little scrap from this.
Also found out the front drive line angle needs some work, it likes to eat CV's
Old Sep 14, 2008 | 06:49 AM
  #57
smashmetal's Avatar
Then I added some new body mounts from 4crawler
shortened the 2" body lift by 3/8". I would have just taken it out but there where to many other things that I would have had to move again like shocks, steering box, and fuel tank. Not worth my time to do it all again.
Started making some nerfs.
Mocking up.
Old Sep 14, 2008 | 09:12 AM
  #58
yotasavg's Avatar
wow this is still a great build. excellent fab work!!!
Old Sep 15, 2008 | 08:25 AM
  #59
Elvota's Avatar
Nice sliders!! Cool rear kickout plate design.
Old Sep 15, 2008 | 06:24 PM
  #60
smashmetal's Avatar
As far as a build go's it will probably be never ending. There always seams to be something new to work on after I wheel it.
It's kinda hard these days to do something diffrent. The main tubes are actually 2". A bit bigger than most sliders are but I think it helps them stand out more!
