93 pickup sas build
Old Mar 29, 2010 | 09:58 PM
Eat_at_Joes's Avatar
93 pickup sas build (complete)
Well i never really thought that i would have gone this route but i think it will be for the better over any ifs lift or lt suspension out there.
So heres the scoop. as the title says i have a 93 pickup extended cab and am doing a sas on it. Im still putting the money together for the rest of the peices and tires so dont get to angry when you dont see me flexin for a bit.
The plan is to do a 4" ifs eliminator kit from all pro along with their 4" lift in the back. trd e-locker front and rear, trussed 84 axle, front diff armor and gusseted balls, 12 volt guys e-locker harness and switch, and 35 x 12.5 mickey thompson MTZ on 15x8 steel wheels. oh and with 5.29 gears.
I cant wait to wheel this when its done!!
Both diffs will be set up tomorrow and from there the front axle gets modded. I'll keep you guys posted.
This is my first sas so let me know if somethins screwy or any suggestions will be appreciated.
Old Mar 31, 2010 | 11:02 AM
94sasyota's Avatar
cool ill be watching i just finished mine a few months ago. all i can say is take your time. its really not that hard. Good luck
Old Apr 3, 2010 | 08:03 PM
So ive heard differnt ways to do this but i still dont know witch way. when i weld the truss on the axle do i need to have the diff inside the housing? ive also heard that it doesnt matter if you just go slow. any thoughts?
Old Apr 5, 2010 | 08:24 PM
well i talked to all pro and like i thought it doesnt matter if you have the diff in or out when you weld the armor and truss on, just make sure you go slow
Old Apr 5, 2010 | 08:31 PM
i also ran into a small snag on my differentials. 1st time was a missing locker bearing, now today is for what ever reason the two flanges are different so i have a triple drilled flange on the way.
Old Apr 6, 2010 | 07:04 AM
dropzone's Avatar
Fossilized
you can also redrill a flange yourself....put the correct DS end on your pinion flange, rotate so holes are not close and drill yourself...saves $$$$
edit: also be sure to stitch weld the axle armor on, don't wanna warp your housing
Old Apr 6, 2010 | 07:27 AM
the holes on the flange isnt my problem, it was that the pinion that i got didnt fit the flange. the flange would freely turn on the pinion so didnt do me any good to use that flange.
also thanks for the advice
Old Apr 11, 2010 | 01:30 PM
So i got the armor welded on and the steering limit plates from the ball gusset kit and started modding the axle housing for the locking diff. the place thats been setting up my diffs noticed that one was standard cut while the other was reverse so have to wait for new gears.
Old Apr 14, 2010 | 07:41 PM
still no progress so some pics of the truck before all this happens.
Who hates ifs? I DO! I DO!
Old Jun 1, 2010 | 09:20 PM
i know its been a long time since my last post so i thought i would fill you guys in. The diffs are finally put together in the right order and i have the axle prepped for drilling the holes for the elocker studs.
quick question how do you guys find the easiest way of getting grease and dirt off of the axle short of sandblasting?
also i havent ever heard this mentioned what do you guys do for recovery points on the front?
Old Jun 10, 2010 | 08:55 PM
wannaBwheelin''s Avatar
I found the best way to remove all the grease and decades of dirt is to use a wire wheel on a grinder. But be prepared to be covered in all of that gunk that was on the axle.
Old Jun 10, 2010 | 10:36 PM
894x4pickup's Avatar
Purple power is the sheet too....
edit P.S. Wheres the pics?
Old Jun 12, 2010 | 12:25 AM
if your talking pics of progress ill try to get some posted soon...
thanks for the advice, i was told bake parts cleaner helps a lot but it didn't do as much as i hoped
Old Jun 12, 2010 | 04:21 AM
bigt's Avatar
engine degreaser works good..
cant wait in a few years when i sas my hilux..
your truck is gonna be sweeeeeeet
Old Jun 12, 2010 | 09:00 PM
tonkatoy89's Avatar
solvent or meguiars degreaser it the pink looking soultion. that thing eats anything and makes your hands slimy so you kno it working. i used that to clean my front axel and it looks good well after i had it sandblasted to lol
Old Jul 12, 2010 | 08:03 PM
axle built
well heres the finished axle minus the wheel spacers and such.
and the elocker for the rear ready and willing
Old Jul 13, 2010 | 08:58 PM
also ordered my tires and wheels today. got 35x12.5 bfg km2's and they will be mounted on a black rock crawler rim (similar anyways) should be here by the end of the week or first thing of next.
Old Jul 31, 2010 | 09:37 PM
Monday is the big day. i threw a grenade under the front of the truck and blew the ifs off.
(or so i wished) spent most the day with the truck on jack stands while on a flat bed pulling all of the components out from under. Christmas comes early this year!!!!
Old Aug 2, 2010 | 01:50 PM
an1mal_69's Avatar
Subsrcibed..
Axle looks wicked, good work
Old Aug 2, 2010 | 02:08 PM
yotamonsta-'s Avatar
Subscribe... gonna order my SAS kit next week so i will be keeping a close eye out....!!!
