91 sas popping sound?
Old Jul 17, 2010 | 08:25 AM
2000taco's Avatar
So the other day i had to stop reallllyyy fast and somthing popped from the front drivers side. got home tore into it and found there was only 2 bolts holding my rotor on and they both sheared off. so i easy out'ed them and put six new bolts in, BUT the hole size in the rotor was bigger than the bolt.. im thinking the sound im hearing is the rotor shifting that little bit inside the hole. I havent torn into it again yet just trying to get some one elses 2cents on it. the only time it pops is when i back up hit the brakes pop, and than pull foward and hit the brakes it pops again than it stops.... HELP
Old Jul 18, 2010 | 11:34 AM
2000taco's Avatar
can any one help! i tore it apart what it is, is the bolts are smaller in diam. than the holes on the rotor, so the rotor is shifting, how do i fix this. its tore apart right now and i wanna get it fixed today.
Old Jul 18, 2010 | 01:26 PM
waskillywabbit's Avatar
You got the wrong size rotor or the wrong bolts. The rotor bolt holes shouldn't have that kind of slop in them.
Old Jul 18, 2010 | 02:50 PM
2000taco's Avatar
ok im not sure what rotor exactly it is but its off a older cruiser, and i have the v6 ifs calipers. my axle is 83. the bolts that hold the rotor on are smaller than the holes in the rotor. the holes in a ifs rotor r the right diam. but it spaces it to far. (i would have to do a ifs widening kit) are the hubs different in a 84 and 85 axle to where they went to a bigger bolt and because mine is a 83 its got a smaller bolt? im really confused on this and need to figure it out asap. wab is there any way i can talk to you on the phone to explain it better (like today)???
Old Jul 18, 2010 | 02:54 PM
You don't have the correct rotors.
The wheel studs should press fit into the rotors through the wheel hub and they should also bolt onto the rotor.
Old Jul 18, 2010 | 03:07 PM
2000taco's Avatar
i have the same rotors you sell. they r fj60s or what ever. so the wheel lug nut studs should not be "pressed" into the hub they should go threw the rotor first?
Old Jul 18, 2010 | 03:09 PM
2000taco's Avatar
from the back to front of the hub mine is set up like this, rotor, hub with the wheel studs coming out of the hub, is this wrong? im so confused and am getting very stressed out.
and if i pull the stud out and put it threw the rotor i dont have enough stud to bolt my tires on
Old Jul 18, 2010 | 03:15 PM
www.ncttora.com/fsm has a diagram of how the front axle should go together, only difference if you have a vented rotor instead of the solid one.
Old Jul 18, 2010 | 03:32 PM
2000taco's Avatar
that shows the rotor bolts to the hub with the 6 bolts the 2 other holes are to put a bolt in to remove your rotor if its stuck on. does not show the wheel studs go from the back of the rotor in. if i give you my cell number can you shoot me a call so i can try to explain it better?
Old Jul 18, 2010 | 03:53 PM
Your rotor is attached to your wheel hub with 6 wheel studs and 2 bolts.
The wheel studs hammer/press in from the back side of the wheel hub through the rotor as you notice the knurled section is in the wheel hub, not the rotor itself.
Back Side of Wheel Hub
Front Side of Wheel Hub
Side View of Wheel Hub
You can hit me up on FB but I don't talk on the phone on the weekend.
Old Jul 18, 2010 | 04:06 PM
2000taco's Avatar
My hub looks nothing like that at all. my hub has 12 holes 6 are filled by the wheel studs and the other are to hold the rotor on.
Old Jul 18, 2010 | 04:09 PM
Take some pictures of what you are talking about please.
Old Jul 18, 2010 | 04:25 PM
2000taco's Avatar
my pictures wont load so i used yours.
Old Jul 18, 2010 | 04:29 PM
Something is definitely not right.
Did you build this axle yourself?
Is it a mini truck / 4Runner solid front axle?
You sure it is an 83?
You should have 6 wheel studs and 2 bolts. That's it.
Take some pictures. Load to Photobucket. copy the IMG code to here
No way to figure out what you got without seeing it.
Old Jul 18, 2010 | 04:41 PM
2000taco's Avatar
the best i can do for a pic. i think its a 83 axle i could be wrong got the truck with the sas in it.
Old Jul 18, 2010 | 04:50 PM
My bet is that is NOT an 83 axle.
Look at the side of the axle tube on the driver's side on the bottom. Any factory truss?
I bet you got one of the weird 79-80 axles with the strange wheel hubs and that is why the rotors don't fit up right.
Old Jul 18, 2010 | 04:54 PM
2000taco's Avatar
it has the axle trus on it. my only guess is it has 79 or 80 hubs for some odd reason.
Could it be a IfS hub?
Old Jul 18, 2010 | 04:56 PM
79-80 have no lower truss.
81-83 half a truss
84-85 have full truss
Those are definitely 79-80 wheel hubs and that is your problem.
Old Jul 18, 2010 | 05:02 PM
2000taco's Avatar
yea thats what im thinkin. so who sells the hubs? i couldnt find them on your site.
Old Jul 18, 2010 | 05:05 PM
I'm trying to find a pictoral comparison, but that is what I'm thinking. Those are not the 81-85 wheel hubs but a 79-80 set for whatever reason.
Try the "Items Wanted" section here, junkyard, Craiglist.
I know FROR used to carry wheel hubs on their site but don't know now.
