87 SAS started!
Old Nov 7, 2013 | 05:04 PM
Teuf's Avatar
When doing my SAS I removed the front IFS drive shaft, of course it was to short and lacked angle. In the rear the longer shackles, added spring and .5 lift block clocked my rear pinion angle up pointing to my output flange at the transfer case. I had drive line vibes, not bad but annoying. In researching drive line specs I saw that it called for a CV in the rear..........I removed my rear driveline and had a shop install the cv and balance it. (Balance thats important).
That having been done I have no shake or off throttle growl.
Now to the front DS. I had originally set it up with the CV and U joint.
31.5 inches flange to flange....... but that was canned in that the CV went to the other end.
(rear)
New plan via driveline angle info said I need a ( UJOINT ) at both ends of the front DS because of the flange angles. I used the U joint yoke cut of the rear and welded it to the front DS.
FRONT DS.
http://i561.photobucket.com/albums/s...psd7c83f57.jpg
http://i561.photobucket.com/albums/s...ps33d83754.jpg
I had the U joint yoke machined to fit the 2.5 square DS.
http://i561.photobucket.com/albums/s...ps88ee28ad.jpg
I hope this helps,,,,,
Old Nov 7, 2013 | 05:09 PM
Teuf's Avatar
Ah you asked about the flanges. I just flopped my flanges. Front to back, back to front.
Old Nov 7, 2013 | 06:27 PM
little_twin's Avatar
That was exactly the info I was looking for, thank you.
BTW, I read through your build thread. Beautiful truck and excellent work.
Old Nov 7, 2013 | 06:56 PM
Teuf's Avatar
Ah thanks, I struggled through my SAS so to speak. If I can help further just ask.
Old Nov 7, 2013 | 07:18 PM
  #25
I thought I read that you used 2.5" tube with a seam and ground a groove in the inner tube. Was that because you weren't able to find seamless receiver tubing? I am just over the hill from you in Sonoma county.
Old Nov 8, 2013 | 08:04 AM
  #26
Teuf's Avatar
The 2 has a seam. When I was going to use a 1.5" inside the 2" tube that was an issue.
I went with 2/2.5 in the end. No seam.
Aye neighbor.
Old Nov 9, 2013 | 07:01 AM
  #27
Aye neighbor.
Where did you get the seamless 2.5" tubing from?
Old Nov 9, 2013 | 08:35 AM
  #28
Teuf's Avatar
Local steel supply.
Old Nov 14, 2013 | 09:33 PM
  #29
I was able to pick up some tires the other day. I got them mounted on an old set of wheels from my chevy. I drove it around the block and am quite pleased with how it turned out. I need to get some paint on the bare metal, weld my sliders on, and get a front drive shaft and it'll be all set.
How it sits now
Old Nov 17, 2013 | 05:41 PM
  #30
Today I put welded 3rd with the 4.88 in the rear. I also installed the new pinion seal in the front 3rd member and will be putting that in very soon. I also installed the rock sliders I made a month ago.
The sliders
Then I went and found a small ledge to try to get the front and rear springs (mostly front) to settle and to check bump stop positioning.
The truck as it sits now in the driveway
Old Nov 17, 2013 | 07:42 PM
  #31
BigBluePile's Avatar
Looks good!
Old Nov 18, 2013 | 04:37 AM
  #32
RobotMoose's Avatar
I'm impressed by the neatness of the welds on the front hanger, good work all around!
Old Nov 18, 2013 | 03:42 PM
  #33
Thanks for all of the compliments.
Old Nov 24, 2013 | 07:56 PM
  #34
I spent a few hours making the bumpstops today. I reused the 4 bumpstops from the ifs for all four corners.
First I cut two pieces of 1 3/4 .120 dom for the front(short) and two for the rear(long). I then cut four 1 3/4 caps and welded a nut inside each one for the bumpstops to thread into. I then welded the caps to the tube and ended up with these.
Then I threaded the bumpstops into the threaded tubes.
I feel that it's important to note that at this point my friend says "it looks like a penis". Hey, at least it's under the truck and not overly visible because by this point i was faiy commited to them. Lol
Finally I welded them to the frame. The fronts are perfect and contact slightly inboard on the spring plate. The rears are about an inch long but still contact slightly inboard on the spring plate. I positioned them so that the have a solid contact point during articulation.
I went and flexed it out a bit to check bump placement.
Old Jan 19, 2014 | 04:20 PM
  #35
Teuf's Avatar
I'll have to get over the hill and check it out someday.
Doug4320
Mar 24, 2018 10:11 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
