4runner SAS: how tall are your leafs?
Old Apr 7, 2008 | 07:00 PM
Kiff's Avatar
About to order up a SAS kit, wondering what leafs I should get? what are other's experiences?
Old Apr 7, 2008 | 07:11 PM
Hayes's Avatar
what size tire do you plan on running? That is a big part of the lift you need. Is this a truck or 4runner? for 33'' tires, go with 3-4'' lift. I have 3'' up front and it is great. If you want to run 35'' tires, go with 5'' lift.
Old Apr 7, 2008 | 07:13 PM
Kiff's Avatar
it's a 91 4runner. I am looking at 35's or 37's whatever comes available really
Old Apr 7, 2008 | 07:17 PM
Hayes's Avatar
then a 5'' lift will be what you are looking for.
Old Apr 7, 2008 | 07:44 PM
yotaman's Avatar
I would not get a 5" lift. I have a buddy running 36" tires and 5" springs. He's truck is TALL. Get 4" front and 5" rear max. If I had it to do over I'd go 3" front and 4" rear but that's just me.
Old Apr 7, 2008 | 08:11 PM
Kiff's Avatar
The only thing I can think why I would go for 5's is I can always remove leafs to flatten them out no?
Old Apr 8, 2008 | 01:14 AM
Elvota's Avatar
I ended up with Marlin 4" fronts and All-Pro 6" rears. This was upon Marlin's suggestion, as All-Pro (at the time) measured their springs differently. Generally, it's common to go 1" more on the rear to help offset some of the additional weight of the 2nd Gen 4Runner. To be honest, even with the 6" AP springs I could never get the tail end level.
I have 35's now, but may up to 37's when they wear out. I envision having to cut some sheet metal or mod with a BFH a little bit to get everything to work. Currently, I have almost no rubbing issue except at a full stuff and full turn... and even then only very minor.
This is a fake CRAWL layout I made a while back goofing around with some Adobe programs.... pretty ridiculous I know, but it does show the dimensions I ended up with pretty well:
Old Apr 8, 2008 | 05:47 AM
waskillywabbit's Avatar
Leaf spring lift depends on a lot of things as mentioned above.
I agree with Yotaman on springs.
I run 40s with a 5" lift but I have no sheet metal either.
Old Apr 8, 2008 | 06:18 AM
Kiff's Avatar
somewhat off topic. Is there a difference in leafs between companies, ie: trail gear, marlin, all-pro? or are the kits all fairly similar?
Old Apr 8, 2008 | 07:14 AM
Do some searching as it has been discussed ad nauseum but your options are limited in Canada with import fees.
Old Apr 8, 2008 | 09:47 AM
dirtoyboy's Avatar
Heres a general guideline to get started....
33-35" tires = 3 inch lift
35-37" tires = 4 inch lift
37'+ tires = 5 inch lift
Use sawzall. Cut to fit
and YES there is a huge difference in spring quality and rates between the different companies...I would recommend doing some research before you drop some serious coin
Old Apr 8, 2008 | 09:55 AM
TOYOTA 1's Avatar
my truck came out a lil wierd. i didnt want body role so i went with 3.5" lift spring in the front and a 5" allpro in the rear. and it sits level! here is a pic on 35"
Old Apr 8, 2008 | 07:05 PM
Kiff's Avatar
how do rears up front size up?
Old Apr 10, 2008 | 06:26 PM
Kiff's Avatar
any input on rears up front?
Old Apr 10, 2008 | 08:03 PM
bigarms23's Avatar
I would order marlins 4inch sas kit but have 5inch rear springs to compansate for the extra rear weight
that will allow you to run 35s or 37s with minor fender trimming and it will give a great center of gravity
Old Apr 10, 2008 | 08:16 PM
UKMyers's Avatar
Another one for 4" front 5" rear. Other options are rears up front and chevies rears.
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
DrZero
18
Jul 24, 2015 11:31 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Nickdigg
Jul 7, 2015 06:04 AM
