2000 Tacoma SAS
Old Aug 9, 2007 | 07:42 PM
gabrielthetacoma's Avatar
2000 Tacoma SAS
Does anyone know a good place to get everything i need. Also, I think that I'm getting an axle from an 85 toyota pickup. would the steering components from the 85 work in my truck? and can anyone give my a full list of everything i need, I want to make sure I'm not missing anything.
Old Aug 9, 2007 | 07:47 PM
V8pickup's Avatar
Allpro sells everything you need to do your sas. If you want to run a 85 axle you need to do something with transfer case. The taco's front drive shaft is on the drivers side and the 85 axle is on the pass side. You could use a Dana 44 or a diamond axle.
Old Aug 9, 2007 | 08:22 PM
DeathCougar's Avatar
Marlin sells the adapter to change your taco trans to a pass side drop gear drive case.
Or just get the Dana44 or Diamond axle.
Also you will have to remove your Rack and pinion steering, and install crossover steering.
Might want to do some thorough research before tackling this one, as with tacos there is a lot more that needs to be done.
Good person to talk to on here is WATRD (moderator) He was one of the first on the board to do the swap, and he used a Dana44 IIRC.
Old Aug 10, 2007 | 05:38 AM
chimmike's Avatar
I suggest you start researching this one on your own, cowboy
Old Aug 10, 2007 | 06:17 AM
AxleIke's Avatar
I do not recomend using the 85.
Your rear axle is 60" wide WMS to WMS
An 85 front axle is 55.5" WMS to WMS
You'll need BIG wheel spacers to get this thing to drive right on the road. Look at D44s. You can get them used for the same price as a Toy front, and you don't have to mess with the xcase.
Flying91
45
Apr 11, 2024 04:39 PM
Kreedy1
Sep 8, 2015 06:33 PM
Tonetrk
Aug 3, 2015 08:47 PM
makemusic116
Aug 2, 2015 05:23 PM
Cplmike
Jul 8, 2015 08:47 PM
