Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
trail difficulty rating qestions
Old 06-20-2003, 11:46 AM
wimpywade94's Avatar
Talking trail difficulty rating qestions
hey all, what trail rating (1-4.5 or whatever it is,) do you think a stock chevy s-10 and a stock heep cherokee take? both have all terrain street tires, and no motor or suspension mods, curiouse if they would be able to make it down some of naches trail cause they want to go with me, what do ya'll think?
wade
Old 06-20-2003, 01:59 PM
crawler#976's Avatar
Of the two, the Cherokee is actually a pretty decent wheeler. They will get thru some pretty rough stuff stock. The S-10 is gonna be the anchor of your group- I'd say it will run a -3 rated trail, while the Cherokee could do a 3 to 3+ if it had too- I've watched a pretty much stock Cherokee get thru a 3.5+ rated trail w/ only moderate body damage and a few good tugs here and there.
Old 06-23-2003, 04:34 PM
yeah we've already decided to leave the s-10 behind take the cherokee or mabey a wrangler, anyways, that just confirmend what i knew! thanks
wade
Old 06-23-2003, 05:16 PM
WATRD's Avatar
On the Naches, two things are going to hinder your group. The first is the lack of lockers. Some of the hill climbs are VERY loose and some have off camber sections that will lift one wheel of a stock rig.
The second is the clearance. The boulder gardens on either side of the ridge section require either VERY careful driving or some lift. On a stock height vehicle, you are almost certain to get hung up or put some serious dents into the skid plates.
I have taken stock Tacoma's through the Naches with minimal damage and that was caused by driver error, but they have been rear locked so they could make the climbs and take lines to avoid the worst of the clearance problems.
Were I you, I would take a lot of strap and a come-along. You are likely going to need both.
kawazx636
10-06-2021 03:03 PM
4x4YOTA
08-23-2016 09:08 AM
primordialbeast117
12-19-2015 12:23 PM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: trail difficulty rating qestions
