Tinkham Nights
#62
The ones I use are waterproof. At least until I bust them up on the rocks. They are commonly referred to as "tractor lights" and have a rubber surround and shock resistance built in.
They tend to look like this;
but can be other shapes as well. You can find them for around $12 each if you shop carefully.
#64
Unless you make a mess of the wiring, it is insulated by the insulating jacket it has. Your connections should be well sealed. but otherwise a carefully wired set up will not have any problems. I submerge mine regularly.
I use some quick disconnects on mine because I mangle an average of one light per month and am always replacing them. Also, they don't like to be submerged when hot, even spashing puddles up on them when they are hot will shatter the lens.
#65
Originally Posted by midiwall
Golly... thanks for the distraction Jim!
click-here
#68
If you solder the wires and then put some heat shrink on there they should be fine. Don't forget to put the heat shrink on the wire BEFORE you do the soldering.
It looks like y'all are having a blast.
#69
Originally Posted by AgRunner06
I just wanted to say that I envy you guys. And that I have a comment on the wiring.
#70
Originally Posted by jruz
The distraction doesn't have to end there...
click-here
click-here
hmmm... The quiet ones are always the folks to worry about...
#71
I think what scares me the most at this point is that you musta' gone looking for this in order to find it.
LittleUgly
15
Jan 2, 2020 01:30 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
