Southeast Fall Colors Run - Nov 5-7 @ Tellico
#561
Originally Posted by dragr1
What? Huh? Don't let Austin and his woman entourage scare you off. You already know that you can run Trails 4,5,6 and 8 with that '85 just the way it is.
#562
more dissapointment
For those of you who didnt know. I have been unemployed for the last month. Well a oportunity came up last night. A job working at Atlanta Motor Speedway. I left this morning and wont be done with job until early November. I will be away from my family and its going to be tough, but I had to do it. Hopefully this will lead to better opportunity's.
Sorry guys,
Dave
Sorry guys,
Dave
#563
Brian,
I can't beleive your not going to make it, I sure hope there is someway you can work things out and make it up here.
Dave, sucks to hear your not going to be there either, good luck with everything tough, hope things work out well and this leads to bigger and better things for you and yours. No one else better drop out, especially Jayson and Jermey, I'm not about to stay at Crawfords without a few of the 4ROC crew.
Jon good luck with getting all your things fixed, you always seem to find a way to pull through.
#564
btw I just found out Indian Larry Died August 30th in Concord NC while not wearing a helmet doing a stunt
the story
#566
Just ordered my 2" RB body lift! WOO!
Whats going on...? Mr. "let see who actually shows up" is backing out? It sounds kind of serious, so I hope everything gets worked out and you can make it!
ps, dave... 10-3
ps, dave... 10-3
#567
Brian,
first off, its Jeremy and Jason. learn to spell fool
i guess we're still going. nothing much is progressing with my truck. spent the whole morning trying to get the supra transmission off with no luck. still have to put the front end of the motor back together after that and then TRY to install it. if theres any major hang ups with getting it turned over dont expect me to show up. i dont know about jason's plans.
#568
I've seen so many people spelling his name JaYson, I wasn't sure if I was the only one missing something, unless there is someone else named Jason that is going. I would love to see both of you there but at least one, I need some familiar faces there, Sam is the only other one I'll know, plus I trust Jason's choice of lines so that helps alot too. Good luck with the engine, wish I could lend a hand, but it's a bit of a drive, maybe when I come to get my sliders I can give you a hand turning a wrench or two.
I finally got my truck back in it's rightful place, and the TJM T15 installed, now it's time to tackle all the small stuff.
#569
#570
Originally Posted by waskillywabbit
BAIN sliders? What is that in your sig? Do you want these or not? I don't want to haul them 10 hours if you don't! You'd better let Jason or Jeremy know something as I'll be on the road in about 30 minutes.
and I'll take care of the rest.
#573
Originally Posted by INsr5runner
sorry guys, but I am backing out of this run.
I will be in Steele, AL this coming tuesday-sunday for a little climbing though!
#575
ha ha ha
got factory 4.88's in the rear and didnt even know it......
pulled the 3rd and the spool is going in tomorrow
replacing the bad rear wheel bearing and pinion seal
then puttin in my new rear extended links
and got all the metal for my square front shaft
so.............. there will be 1 more runner for Tellico
#576
Originally Posted by customcruiser
ha ha ha
Soooo, all that means your going to be there, in a trail ready rig? Sweet, I can't wait to see the monster.
#579
Austin do you have a write up on how you installed your CB, I like the location of your antenna, and if it's not to hard to do so I would like to copy that. I rather not mount it in the spot that TJM provides on the T15, but if time is the determining factor that may be what happens. :pat:
#580
If I only looked before I ask dumb questions, it's on the 4ROC NC site. There I flammed myself, but feel free to add your .02By the way we need to update my page on there, you can just copy Darrens infor and throw it into mine seeing how it's his Runner I have now.
